Does anyone know what this plug is called ??
Mc Tool
Most common name is a body plug if its on a car ( they have heaps of them ) but I dunno what the outboard peeps would call it . You should be able to get one from an auto parts shop for a couple of bucks .:)
rolmops
I'm not at all sure that this is the original plug. At least on my pre 1972 outboards there is a rectangular little metal plate, which is the same color as the rest of the lower unit, that is held in place by 2 screws. It is called a "cover plate"
Typical of a plug used on " offshore " small motors.----Honda refers to it as a grommet.
rolmops
It looks like there are 2 motors. The blue one looks like a pre 1972 Evinrude, the other one I do not recognize.
Mc Tool
Ahhh Im pretty sure they are the same motor ..... just different camera settings .
Nordin
These grommets are common on 70.es and 80.es japanese engines such as Suzuki, Yamaha, "japanese built" Mariner and maybe Tohatsu (Nissan).
Cover for the shift linkage coupler.
Thanks alot I found the name in the parts list, it is called a outboard driveshaft housing grommet
Mc Tool
Or its a grommet that fits in an outboard driveshaft housing :).
To me a grommet has a hole in it .... like for getting a wiring harness thru a bulkhead .
airshot
Yep...have to agree with ya....I was always taught that a grommet fit inside a hole to protect the sharp edges from chewing up any wires or hoses that passed thru that hole in the grommet. If no hole then it was called a cover.
Years back made a tool ( mold) that cast these things from plastic and those were the names used by the mfgr. I guess there are some others that might call them doohickies, or whatchamacallits.
Nordin
The engines in the pictures are a Yamaha and a Mariner (same as Yamaha but different color).
In range 4-8Hp.
