Trailer Towing Capacity
alldodge
Thoughts on towing Tractor, have 2 options
Trailer, 10 Ton Tag with electric brakes and pintle hitch , plate list 10K pounds max, and trailer weight in 5500 pounds
Tractor, M9540 no loader, weight list 5095 to 6175. Have methanol in rear tires
1997 International 466DT single axle dump with juice brakes (26K limit)
2025 Ram diesel with HO motor, class 5 hitch (20K limit but not with pintle)
So have maybe 11,675 with trailer and tractor distributed between trailer and truck
Pmt133
I'm fuzzy on the new rams but what's your limiting tongue weight on the class V? Like 2000lbs or so? You should be way under payload even on a 3/4 ton unless you have a lot of... stuff... in the truck
As long as you're loaded to 10% on the tongue I'd say you'd be fine with either.
alldodge
My thought also, the dump has more than enough tongue capacity. The class 5 list around 2700
Swap pintle on trailer for 2-5/16" ball
Hook up ram, toss trailer spare into truck bed
Enjoy the A/C and tunes
