Troubles with 8HP
Kissdude
So I’ve replaced the switch box on my 8 hp Mercury outboard and now have spark, compression and fuel to the carb. When I try and pulls start the motor does nothing, not even try at all to start.. any ideas? Thanks
Jeff J
Fuel mixture is the first thing that comes to my mind. Fuel to the carb isn’t worth much if it’s not letting a combustable mixture through it.
Kissdude
Can I try a shot of starter fluid?
Remove sparkplugs.-----Put 6 drops of gasoline in each cylinder.----Install sparkplugs.-----Try and start the motor.----Report what happens.
Jeff J
Racerone has the better/safer idea. Starter fluid can be little dynamic for my tastes.
Kissdude
I’ve added the six drops and nothing, won’t start
Kissdude
I'm wondering if maybe the lanyard switch is giving me issues, i wired the new switch box but not 100% sure how those go in?
With a few drops of fuel in the cylinders the motor should BARK / ROAR like a dog or a lion.----You have no spark , weak spark or spark at the wrong time !!
Kissdude
I’m sorry, not sure what you mean. I have the spark test lights and when I pull start they light up on each one. I put 6 drops of gas in, pulled a few times and nothing happened. How do I know or fix spark at the wrong time?
Glowing light spark testers will fool you.----Does spark jump a gap of 3/8" on both leads , yes or no ?----Easy to make a simple tester with some wire , glue and cardboard.
Kissdude
I also had plugs out and grounded them, yes I have good spark. I need to know how the safety circuit works or if I can start it without that hooked up. It doesn’t fire at all
See post #14.----Does spark jump a gap of 3/8" , yes or no??-----The safety circuit prevents spark.----If you answer the questions you will only help yourself.------Or hurry and visit a shop to help you !
Kissdude
yes spark jumps a gap of 3/8" so, what now?
