4.3 GL-D Electrical Issues
These are the numbers on the engine cover sticker.
4.3 GL-D
3869251
4012141889
Took the boat out Saturday. Pumped the throttle a few times and it started right up, ran for about 10 seconds and died. Couldn’t get it started afterwards. My mechanically inclined neighbor took a look.
1)The fuel pump relay tested good
2) the pump above the fuel filter ran when power was given below the relay
He looked something up and said the relay should get its signal from a switch that is hooked up to an oil pressure sensor. We found an oil pressure sensor on the top of the motor but couldn’t find a switch. I’ve only had this boat a couple months but I’ve always had to manually pump the throttle a few times to get gas into the carb to start it. Also I’ve never heard the fuel pump prime when I switch the ignition to on. His going theory is the main fuel pump that’s on the tank has not worked since I got the boat because the switch that is supposed to send the signal to the relay was removed or never installed when the engine was swapped (I was told the engine was swapped when I bought the boat, but don’t have any more info). He said the filter may need to be replaced or maybe the accelerator pump is worn out from doing all the work. We’re going to change the fuel filter and see if it starts. Just trying to see if this makes sense to anyone here and if anyone knows where this switch between the oil sensor and the fuel pump relay is supposed to be.
The engine was swapped before I bought the boat and I’m trying to figure out what these go to. One I think is a ground wire, the others I don’t know. We think there something that’s supposed to connect to the oil pressure sensor that is missing. I recently added a Bluetooth adapter to the factory radio’s cd port input. While installing I realized the remote and power wires were all connected together so disconnected and connected them separately. The radio worked fine until I started the boat, then it had what sounded like electrical interference coming from the running motor. I assume this has to do with the ground?
4.3 GL-D
3869251
4012141889
Thanks for any insight!
alldodge
I'm going to merge your wiring threads because while it is 2 different wiring issues they are both wiring issues, and this will help others keep up with issues
The second pic seams to be coming from the exhaust and is a Tan wire. Might be Tan/Black and if so it goes on the exhaust overheat sensor. There is one sensor on each exhaust
The first pic might be for bonding and has had a piece of black wire attached to it. If so it's goes to ground
This is a V8 but wiring for sensors is the same.
alldodge
Your friend is thinking about a Merc and VP does wiring different for the fuel pump. When cranking the Yel/Red wire sends power from key thru Yel/Red wire to a diode and then to the relay. When cranking power energizes the relay and turns on the pump
Once running, power is removed and relay is energized by the alternator sending power thru another diode to keep relay energized
Got it, so when actually cranking, it should trigger the relay?
ESGWheel
Ensign
Wow this is a lot to unpack here. Taking some of the points in no particular order:
  • Unless you can post a picture of it I do not know of any tank mounted fuel pump. There is one low pressure pump that is mounted on the engine.
  • The pump does not turn on with “Key On”, only “Key to Start” and once started stays running form the Alt. See AD’s close up pic.
  • A study of the wiring diagram will show the oil pressure switch, and the exhaust temp sensors go to the helm for an alarm. There is not a low oil pressure cutoff the fuel pump.
  • With a carb’ed engine you always need to pump the throttle to start when cold. Sequence should be like this: Key off. Depress neutral button on throttle, pump its full stroke once (may need two but start with one and go from there), back to idle on lever and then key to start. And depending on your choke status, you may need to, while key to start, have the throttle again in neutral and slowly move it forward but not to exceed say a ¼ of the way, you do not want the engine to catch with the throttle at half or full > it’s a good way to shorten its life.
  • Accelerator pumps can wear out / fail. An easy way to tell is to see if it squirts. This assume the carb float bowl is full > see the thread as KD suggests in post #7.
  • For the radio interference, not sure what you did, but could be a grounding issue. More likely need a filter (also called a choke) in the power line.
My suggestion: Once you have all your wiring squared away and are still having issues getting it started, start a new thread. Thanks.
This is helpful and I’m going to attach a picture of what I think is the other fuel pump. I was just reading that fuel injected models have 2 pumps and I’m wondering if this boat originally had the fuel injected GXi.
ESGWheel
Ensign
Fuel injected do indeed have 2 pumps: a low pressure and a high pressure. Both assembled together as a fuel pump assembly. Here is a pic of one:
ESGWheel
Ensign
Its always good to have friends that want to help but be careful…. This forum is the No. 1 site to help and provide appropriate guidance IMO and other’s (see posts 11 and 12 of this thread, link). Frankly, I would not be spending my time here if I thought it was a bunch of wannabes.
Keep reading as much as you can on this site, ask lots of questions (but only after doing some research yourself, which aids in the learning) and yes, you will figure it out. And we will help. :)
Are you new to boating?
Yep! 1st boat and don’t really have anyone experienced to show me the ropes. This site has been a tremendous resource. I’m definitely taking the advice I get from friends and running it through here to make sense of what’s what. Not working at the moment so hopefully when I am I can get some of this done at a shop but even then, it’s nice to know if a shop knows what they’re talking about or not. And getting some of this stuff squared away my self might make more economical sense even when I am back to work. Should have bought a boat right when I lost my job instead of waiting! That and should have bought more sweatpants.
ESGWheel
Ensign
Well please check in here before taking it in. Some aspects you may not want to do like pulling the sterndrive but again this forum can help.
Since new, suggest reading these two threads link and link.
Well, changed the fuel filter and it runs fine! The filter that was on there was pretty loose so I wonder that was the main culprit.
ESGWheel
Ensign
Great news. And yes, a loose fuel filter could allow air to be sucked in and cause issues. So, no need for new thread for “no start” condition.
How is are the wiring issues that started this thread working out? All set?
I took a closer look at that wire and took a better picture. Based on the diagram you gave me, I think it goes to the oil pressure switch (which I cannot find). There’s another diagram I found that says it’s for a 4.3 gl (attached) but it doesn’t show the 2 Exhaust Overheat Sensors (which are on my motor with tan/black wires, just as your diagram shows).
The diagram I found, which may be wrong, also shows a tan/black wire going to the alarm (which I also cannot find).
Any clue where I could find the oil pressure switch and I can check and see if it’s missing its wire?
Thank you!
