Hot water heater
rickasbury
Master Chief Petty Officer
Ok, back in the water. Someone else suggested with the boat running and the pump switch off, if the water comes out than the heater core is bad...but that would say that it is hot water coming off the heat exchanger circulating in the heater and not coolant. These heaters are not cheap! Would you all concur?
kd4pbs
Turn off the pump, then open a hot tap. Let all the pressure bleed off, then close the tap. Start the engine and run around a while, heating all the water in the tank - probably 20-30 minutes or so. With engine running, open a hot tap. I would imagine a small amount of water will come out due to the expansion of the water. If lots come out and continues to flow, then you've got a bad water heater with a hole in the heat exchanger portion.
Yeah, those water heaters are not cheap for sure.
Another way to find out would be to bypass the coolant loop in/out, pressurize the fresh water side, and see if water flows out of the open coolant loop of the water heater.
muc
It's been over a decade since I winterized a water heater. But it looks like the check valve is screwed into the hot outlet, should be in the cold inlet. Take a close look below where those hoses go into the heater. Should be a C and H stamped below them. If someone got things mixed up you can get hot water at a cold faucet, but only for short time, it will turn cold in a minute.
rickasbury
Ok- think this one got figured out. There must be a small leak in the heat exchanger inside the water heater which is pressurizing the system with really hot water- so the water will run, super hot without the pump being turned on. From what I read is not serviceable- but what i read today, the electric side should still work. I would pull the lines from the engine and loop those together. The unit will then work on electric on shore power or genset...that sound right?
Grub54891
The heat exchanger will still leak out so it will empty the water tank. Unless you cap the hoses or plug them.
Comogene
Something does not make sense. The closed loop engine system circulates coolant. The water heater is tapped into that system. If there is a leak in the water heater's internal heat exchanger, it would be coolant from the loop into the fresh water system inside the water heater. You would be loosing coolant in the engine system and that coolant will come out through a fresh water faucet. If it is just hot fresh water, you do not have a leak in the loop system. It is simply a backfeeding of hot water from the heater into the cold water side. If you run that faucet, the hot water should dissipate rather quickly and be followed by cold water. This is why many systems put a check valve in the cold water feed side to the heater in order to prevent the back flow when the pump is off. If you have a check valve on the cold water side - it is stuck open.
Comogene
Another issue: it does not appear that the "winterizing" system is properly plumbed, if in fact it is utilized for winterizing. You need a second diverter valve on the hot water side of the "T" to prevent the antifreeze from flowing back into the heater. The process would be to close both valves, thus routing the anti-freeze through the cross-over piping and not through the heater. Open the faucet at the bottom of the heater and open the pressure relief valve to drain the heater. In the Spring, flush fresh water through the system, open the two valves (which will close off the cross-over) to fill the heater and turn it on.
rickasbury
Good morning!
I'm reviewing your comments, thank you for posting your thoughts.
The boat is a florida boat so perhaps it was not set up for winter? The boat had 50 hours on it when I bought it. It did come down from the panhandle which can get pretty darn cold- maybe someone has messed with it but everything has worked for like 10 years.
rickasbury
Intersting thoughts- if it indeed is leaking coolant into the water system it's not real apparent. Can't really go by the reservoir, unless it was just empty. I popped the engine heat exchanger and it was pressurized and full - so I'm suspicious of diagnostics but don't have another explanation. A new heater is about 600 bucks.
I believe the primary reason that everyone has leaned to this is the fact the system pressurized with the engine only running and up to temp. The hot water does not stop coming. I've had the boat for 10 years and has never been as issue.
So if you operate any of the faucets engine running (but before the thermostat opens?) It'll operates fine but it seems once the engine gets to temp the fun begins. And is super hot. I guess i got to the point of whether it is a heat exchanger failure or not, it must be something else internal? I'm certainly open for anything to try- the only thing that happened just prior to the issue is I replaced the water system pump- but was totally plug and play. I can't imagine any connection there? Is there something I'm missing there? It all seem to happen at about the same time. I don't recall if I ran the boat with the repair without issue as sometimes I have big gaps of usage...
Grub54891
I think if you do the bypass of the hoses would be a good test of what’s going on. If it doesn’t get hot when bypassed you narrowed it down to an issue with a check valve or heating coil. You could pressurize the hoses separately from the system and see if it leaks down.
Comogene
If you do not have a check valve in the cold water feed to the heater, and it appears that you do not, I suggest that you install one and see if that resolves the issue. It should be before the cross-over to the hot water side of the heater.
If you do not taste or smell coolant in the "hot" water coming out of the cold water faucet, you do not have a leak inside the heater. Engine coolant pressure is 7-14#s while fresh water system pumps run 30-60#s. Yours appears to be 55#s. If the pressure in the fresh water system drops below 55#s, the pump should automatically turn on to repressurize the system. If you manually turn off the fresh water pump, then there would be a possibility the engine coolant pump could push coolant through a leak into the heater, but you would taste and smell it in both the hot and cold water faucets when you open them.
If there is no taste or smell of collant from the water coming out of the faucet, my best bet is it is a backflow issue that should cured by a check-valve.
rickasbury
This all sounds good- but- what would be the explanation for why has this now become an issue on a 2006 boat? It would seam that a waterheater would be a pretty simple contraption! Externally, I see only the one valve - possible that valve has failed? I found not see cold water line for water to the heater- but what would perserize that to happen?
rickasbury
I guess i have to really look at the water distribution. I don't know where the cold water is going into the tank for one. I have one cold water line and one hot- i have only one faucet that is cold only- I have the swim platform, the head and the galley sink that have both hot and cold. I assume then the hot runs to one and probably a t to go to the next. When I look at the heater, you have a red going over to a blue cold line with the valve- what is that set up?20250812_153010.jpg
Grub54891
I guess i have to really look at the water distribution. I don't know where the cold water is going into the tank for one. I have one cold water line and one hot- i have only one faucet that is cold only- I have the swim platform, the head and the galley sink that have both hot and cold. I assume then the hot runs to one and probably a t to go to the next. When I look at the heater, you have a red going over to a blue cold line with the valve- what is that set up?View attachment 413319
That valve on the cold line is a bypass for winterizing. Perhaps it’s broken internally. In the position it’s in now, it should work normally. When winterizing you turn the valve so it bypasses the heater as you do not want to fill the heater with anti freeze, you simply drain the heater.
Comogene
I am in agreement with Grub and he has a good point. The blue tubing is cold water feed. The red tubing is hot water out. The valve on the cold water side is utilized to divert the cold water feed and not allow it to enter the heater. While in the normal position, hot water exiting the heater is not allowed to enter the cold water line and back feed. If the diverter is broken, it would possible, but not likely, for the hot water to flow into the cold water line. My thoughts are to remove the valve and cross-over. Blue directly into the heater. Same for red. Then there should be little chance for a backflow of hot water. A one-way (check valve) on the cold water side just before the heater would do the same thing. Your new pump may have more or less pressure than the old one and that may be the catalyst for the problem. Again, preventing the hot water from entering the cold water line is the objective.
rickasbury
Not having taken one apart, there are only a couple of opportunities for hot water/coolant pressurized to take over the faucets. It really makes no sense n se to me- I'll take the coolant hoses off and I'm pretty sure it will stop. If I can still use it on shore and electric I can get by- but if I can fix a valve then I'm in.
I'll get back to it.
rickasbury
Ok, update for any following. I cut the crossover line and capped both ends. I had about a quarter tank of water so I thought I'd just back it in the water and let it come to temp...it seemed to be working ok- I left the pump off and turned on a cold faucets and one of the hot. Seemed to work ok but figured I'd need to test it with full coolant pressure. Everyone seems to think there is a leak in the heat exchanger which would put coolant and pressure into the water system even when it is off right? I had forgotten my cell so ran home to get it. While there, I wanted to refill the water tank. I put the hose in and it quickly started to flow back out of the tank- but not the vent. I pushed the hose tight and "phew" this wad of yuck files out that vent. It looked to be leaves and like some critter was nesting. I was on the water yesterday, it worked perfectly...go figure?
rickasbury
That did resolve the issue. Also had a blocked tank vent if that could have possibly caused it.
rickasbury
It does not appear the heat exchanger was the issue. Please read last post and comment- driving me crazy!
