Solar charging batteries
redneck joe
Any pitfalls I need to know?
Planning on one for the main battery and one for the trolling motor bank. I'll use a two pin minkota type male/female connector rather than hard wired. Looking for a panel that can clip on.
redneck joe
And is this or similar what I want to know how much charge I have left like I can see on my ryobi batteries?
Meter
redneck joe
Oh and batteries are lifepo with built in bms and old school lead acid in back.
Can't seem to find any clip on ones.
StewartL
Meter
Yes, a few pitfalls.
You cannot use one meter for two separate battery banks. You must have one meter per bank, permanently wired to that bank's positive and negative. A plug-in connector won't work because the meter needs a constant, tiny power draw to monitor voltage. Unplugging it resets it and makes readings useless.
For LiFePO4, ignore "percentage" meters designed for lead acid. They are wrong. You only care about voltage. A simple digital voltmeter is best. Learn these key voltages for LiFePO4:
13.3V+ (100% charged)
13.1V (~50%)
12.5V (20% - time to recharge)
12.0V (0%, damage imminent)
For your lead acid, a voltmeter is also fine. Look for panels with a digital voltage readout, not just colored bars. Hardwire each meter to its own battery bank.
dingbat
How so?
Both of my banks are wired to a common gauge with a selector switch on the input
tg3690
This is false......my boat came from the factory with one meter with a selector switch for 2 banks. Works just fine.
StewartL
Factory-installed meters with a selector switch work perfectly. They are the correct and standard way to monitor two battery banks.
StewartL
How so?
Because a selector switch only shows the voltage of one bank at a time. You can't see both voltages at once, which is a major pitfall if you're trying to monitor their state.
Mc Tool
Disagree Turn the selector switch back and forth as needed.
yeah but Im thinking (analogy ) that on a twin engine set up you have an oil pressure and overheat alarms for each engine ......not one warning display switched between engines because both need to be monitored. Bastards luck would see the unmonitored engine blissfully melting down while your display is switched to the other engine .
I dont have a ton of experience but I think if I had one bank of lithium batteries and one of lead/acid batteries I would want separate monitoring.
tpenfield
I did the solar charging thing over the past few years. You will probably want a solar charge controller, one that has setting for LiFePO4.
I also found that when the LiFePO4 batteries are full, they shut off charging, so the controller may have current with no place to go. So you may get a voltage spike. Not sure that will break anything on your boat.
As you get things hooked up and working, be ready to make some adjustments, based on the what system likes and doesn't like.
dingbat
They these batteries so failure prone that they need constant monitoring?
My fuel tanks are on a selector switch. Takes me all of 10 seconds, if that, to review both tank levels.
Coming from a 99.8% uptime industry, we don’t overly complicate things by adding unnecessary instrumentation and wiring.
kd4pbs
The problem is that you're relying on both meters to be accurate.
In most industries, situations like this call for a single indicating/measuring device which can be switched (manually or automatically) between multiple devices that are being measured to eliminate any problems with a measuring device going North and giving false indication.
Am man with one clock vs. two, and all that...
redneck joe
Ok so this sorta got off track, gauges can be dealt with as needed but dont need guages if you don't have a charger.
So....
Went to look at the one i bought two years ago to power my deck light and it is listed for lead acid only, nothing about lifepo. The battery is a lifepo. Two years no issues other than black wire death which is not confined to any specific battery type.
Dug deeper on the amazon and of course they have ones listed for lifepo specifically plus all types.
Why is my old one ok after two years?
Seems like all the ones I find for lifepo have a bms but so do the batteries which is why I bought them in the first place?
Mc Tool
So....
I just got an Amazon smart charger and it says ( and you'd need to be a linguist to decipher the translation to english ) not to charge lifepo batteries without BMS , which I assumed was part of the battery.
Pissed me off :D I actually had to read the bloody instructions ........one of them things that does 20 things but only has one🤬 button .....with an auto lockout 😔
redneck joe
Decided on a 5 watt panel, 5 inch wide will bolt down on the top of the gunnel. I think 5 w is enough to both charge after a couple 4 days of sitting as well as act as trickle for the winter. The bow points due east when in the barn.
Mc Tool
After reading up on it a bit I find that a battery tender will hold the battery charged , mine has no voltage/charge control at all , puts out 20v with no load, reads battery voltage when you hook it up . I have a 210a/h battery and it keeps that charged . I am told that such a tender wont charge a flat battery , but any thing that will charge that battery shouldnt be left permanently hooked up ........well not the cheap ones anyhow .
My boat lives in a shed otherwise I would fit the panel more permanently......whats a gunnel .......is it like a gunwale 'cept spelt wrong :D:D
