[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
Ted, since you would be having the fab work done externally if aluminum and you would have to build plugs/mold/parts if fiberglass, how is that easier?
Good question . . .
If I do fiberglass, I can potentially make the bracket a hull extension spanning across a greater width of the transom's irregular shape; basically going to/near the inside of the trim tabs.
If I do aluminum, it would be more feasible to make it as a bracket, just covering the width of the straight/flat portion of the transom.
Ted, I was going.... you simply pay to have a fabricator make the aluminum bracket (no mater what shape) and you have to physically do the work yourself to do it out of fiberglass.
tpenfield
September Update . . .
Boating season (for us) has come to a close, and over the past few months I have been firming up plans for the outboard conversion. My 3D modeling software has come in handy in finalizing the design.
I plan on making a gantry for the heavy lifting . . . the rear seat assembly has to come off in order to pull the engines. . . probably weighs 400 lbs. Then I can use the gantry to pull the engines.
I am going with an outboard bracket that will also serve as a hull extension, what I am calling an 'extendo-bracket' :LOL: .
In designing the bracket, I wanted to take the shape of the boat's transom into consideration.
The 'flat' part of the transom is inset quite far and covers only about half of the boat's beam.
If I went with a traditional bracket, it would be only about 58" wide. Certainly wide enough for the twin engines, but probably falling short on the hull extension/planing surface criteria. So, I decided to go with the 72" width as a compromise, not messing with the trim tab areas.
Another consideration was fiberglass vs. aluminum. If I go with aluminum, I would probably want to have a space between the top of the bracket and the underside of the swim deck (corrosion prevention consideration). This would mean that the bracket would need to 'hang' off the transom. Considering the proposed length of the bracket ( 65") . . . that seems like a lot of cantilever.
If I go with fiberglass, (probably Coosa-cored fiberglass construction) I can more readily attach the bracket to the underside of the swim deck, making it be more like a hull extension. The contact areas of the extendo-bracket will be something like this . . . (shown in orange)
The extendo-bracket will have the mating contact areas as illustrated below. . .
The installed extendo-bracket will look something like this . . .
I am planning on a 2" step of the hull extension portion and its planing surface length will be about 40".
There will be adhesive and lots of fasteners holding the extendo-bracket to the boat.
Probably about 80 fasteners (SS bolts) in total. My technical assessment is that 'it's not moving' . . .
Cruisers Yacht sent me pictures and drawings of the OB version of their boats a while back, so I could see how they add bracing to the transom area in support of the bracket. I plan on doing something similar with an added 'cross bar' at the top of the transom. (The bracing is shown in white, added to the top of the existing stringers).
As for the engines, I am thinking 300 HP for the twins . . .
Speaking of engines: I've got some quote requests out and have a first set of #'s back . . . A bit more than I had estimated, but not terribly so. The quote I have is all the top-shelf stuff, more than what I was looking for, so there should be some wiggle room. Basically the controls and rigging are more than the cost of an engine :rolleyes: . . . .
Anyway, I'll post updates as things get rolling . . . the boat will be coming out of the water in the next week or so, then the conversion will be 'Job 1' for the next few months.
Ted, the gantry is similar to what I used in my storage unit back in 2011. I did not use the kick braces on the sides, instead using plywood. the walls of the storage unit helped.
your legs of the A should be turned 90 degrees
your fully dressed motors are closer to 800#. the A-frame tweaks below will pick 1500# without a problem
tpenfield
One thing that I am still thinking over (or maybe over thinking :LOL: ) is the 2" step (up) of the extended planing surface. I see a lot of hull extensions that are done with the added planing surface flush with the existing hull, rather than a step. I'm thinking the step will allow some air underneath the added planing surface, much like a stepped hull design.
I'm still looking for some real-world examples.
tpenfield
As for stats & numbers . . .
If I build the extendo-bracket (EB) myself, it is looking like $5-6K including the gantry for materials and supplies. I am thinking to have one made is probably $12-15K.
I have estimated the weight of the bracket in foam/fiberglass at 475-500 lbs. If aluminum, I came up with about 630 lbs.
As for buoyancy, the EB will add about 1700 lbs of buoyancy to the stern, so I calculated roughly 2.5" of lift at the stern. With the I/O engines, I was always looking to move weight forward. Upon the conversion, I'll probably be looking to move things towards the stern a bit.
As for budget, I am looking at a total of $85-90K all-in. I am having shops quote a 'trade-in' of the I/O engines and controls as part of the deal.
tpenfield
The more I read about the design of hull steps, the less inclined I am to having the 2" step. Here is a rendering of the E.B. without a step. There is a strake right at the chine of the extension (not previously detailed) that I could run to the end of the extension.
tpenfield
After some review of the boat hull (from pictures), I realized that I had the hull strakes slightly off. The upper strake does not line up exactly with the chine of the hull extension. Here are a couple of pictures with the strakes shown and adjusted accordingly.
I should be getting some more engine pricing over the next couple of weeks. . . . Later this month the 'fun' starts.
Lou C
Your brothers old boat had the 4.5/250 hp correct ? How did that do in a 20-21 ft boat .
My current boat is 21 ft with a 5.0 with 4 bbl edlebrock on paper 260 hp… like the size but when I have 8 ppl one of which is one the rope wondering if 4.5/250 hp cuts it
I think it was the 200 hp version, it seemed faster than that to me but maybe some of my boat's 205 hp have gone out to pasture lol. Our old boat is slightly larger, and heavier it seemed.
We never had 8 ppl on it though, usually only 4. He ultimately traded it on a similar boat with an outboard because he didn't want to start with the endless maintenance that comes with mooring/running one in salt water. I've done it and wouldn't have one again, if I were in the market right now I'd be getting a dual console 20' with a 150-175 hp outboard. Perfect boat for my environment. Every year you see fewer and fewer sterndrives here.
I will say the Merc 4.5 V6 even though it appears clearly based on the old GM 4.3 if you look at Merc parts catalogs, it is far more refined & smoother than the old carbed 4.3, and in fresh water would be a nice engine to have powering a smaller boat. Not sure how it would compare head to head with an EFI 5.0 or 5.7 in the same size boat though.
tpenfield
Quick Update . . .
September has been with lots of life happenings . . .
  • New grandbaby, 👶🍼 so the Admiral and I are helping out.
  • College buddy get-together later this month . . . we tend to do this every few years. 🍻
  • More home improvements on the summer house (750 sq ft of hardwood flooring just got delivered). 🏠
  • Need another visit to the dentist to get a cap fixed. 🦷
The boat does need to come out for the season at some point . . . 🚤 :unsure:
I've compiled some data about the engine choices, seeking to gain some insight. I've noticed that the manufacturers don't readily publish Torque/HP curve data. So, it may be anyone's guess as to how the different engines are getting to their numbers. I have not found any published power curves for the outboards. :unsure:
I find the Mercury numbers of HP/liter interesting vs. the others, but if I had to guess, I would imagine that low-end torque may be their strength. Since my boat is fairly heavy for its size, I tend to favor low-end torque, because without it, you may never see the high-end HP. :LOL:
I've also fancied-up my drawings and have been working out some of the details.
Having the boat with the full original swim deck and the boarding ladders to each side should be a big 'plus' vs. how CY does their reduced swim deck.
There is going to be about 40" of additional planing surface, which should help the boat come on plane and ride better. (time will tell)
alldodge
Yam and Suz are using superchargers which will increase the maintenance and reliability IMO as well.
Looks like they are not supercharged, the Yam needs premium fuel but not Suz
Hey you could move your CoG more forward if you add more anchor chain :D
Scott06
Quick Update . . .
You might also compare cost of extended warranties, this is probably insight into how much the manufacture knows they will cost over X years. I think Muc had pointed this out on a thread a couple years back.
tpenfield
The CoG Moving back might be OK considering that there will be quite a bit of buoyancy and planing surface at the stern.
Lou C
While the cost of outboard repairs may well be higher due to parts cost, most salt water boaters are choosing the outboard option no one seems to want to deal with the added maintenance sterndrives need every year….
tpenfield
As for extended warranties- Yamaha seems to be about 15% lower than Merc and Zuke.
It looks like the standard warranty is 3 years for M and Y, 5 years for S.
I’m not a fan of warranties anyway, probably would stick with the base warranty.
tpenfield
The pricing for extending the base warranty looks to be $1,000 - $1,200 per year, which seems high, as that figure would be an average. Not sure how much of it is clear profit, but at ‘flat’ rate, every 10th owner would have a $10K repair bill each year. 🤪
That warranty is an accrual amount, based on about a 17% failure rate, and the average price of the parts and labor
