Shift cable bellows.
wengr
Hello, I'm trying to replace my shift cable bellows. I have it disconnected from the engine. I'm trying to pull it through the transom and I hope to avoid removing the outdrive. The problem is that there seems to be a plastic grommet where the shift cable exits the hull, and it is preventing the cable from passing through. Many people on youtube claim to have done this successfully, but no one mentions this plastic grommet. Their cables just pull right out.
I am aware that this is not the factory approved procedure, but even if I take the drive off now, the cable will still not pull out through the transom. Any advice appreciated.
Jmunk
On my Alpha 1 Gen 2 the shift cable had a plastic spiral warp on the cable for protection that needed to be removed first. Just reach in and unwind the wrap, must be done from inside the bilge are.
ROY WILLIAMS
cable outdrive shift engine switch ....
cable oil hoses rubber! 24hrs oils!
outdrive rebuild!
nola mike
Don't know what you're working on, but if you tried to remove it without removing the plastic spiral wrap you may be in for an adventure. I'm not aware of any grommets on the alphas at least. Btw, just remove the out drive. Doesn't sound like you've been doing the maintenance on it anyway, it makes everything easier (honestly can't see how you would replace the cable with the drive on anyway) and it's literally 3 minutes to remove and 5 to replace plus a gasket.
wengr
Thanks for the replies. There was no wrap on this one. The problem is the plastic grommet that is installed from the bilge side. As this is a 5.0 the grommet is inaccessible. I had to cut the cable in order to remove it. So I lost the string path that I had hoped to maintain. The drive is off and I will now be installing a new QS cable and bellows. Can anyone please describe the best path for the the cable?
Bt Doctur
wengr
Still struggling with this. The original shift cable jacket would not come out through the plastic grommet. I had to cut it in order to get it out. Now the replacement cannot be installed because of the grommet. From what I see, the grommet cannot be removed with the engine in the boat. No idea how to proceed at this point.
nola mike
find a picture of the grommet. I don't think anyone has any idea of what this part is.
wengr
This gentleman mentions it at about 1:51
Forum won't accept photos from me.
nola mike
ok,
I think I see what you're talking about. one of the two items to the left of the gasket here?:
wengr
Yes Sir. They include a long one and a short one. I can't say how long my original is, but I can say it has a smaller inner diameter, and that is the problem. Maybe I can destroy the existing to get it out, but the replacement is difficult as it installs from the bilge side.
wengr
So I finally have my new Quicksilver shift cable and boot installed. (grommet which I suspect is not original needed some reaming) and now I am trying to adjust the shift cable. After researching many descriptions of the process, I see that a commonality is the statement that "while pushing in on the lower shift cable, the prop should lock while trying to turn it counter clockwise".
My prop does not lock, and the adjustment process fails.
The lower drive was removed first for impeller replacement, and then the upper was removed for shift cable and bellows, so I suspect that something was out of sync when I put it back together? Any suggestions appreciated.
nola mike
Not knowing what you did, it's certainly possible to screw up the shifting when you split the drive or not engage the shift rod when reinstalling it. Does it lock in the other direction when you pull the cable out?
wengr
I think the proper answer is no. Sometimes it will lock, but if the prop is jiggled it will release. There is no full engagement either way. If the cable is pushed in about half way, the prop spins freely and silently. Which I would assume is neutral. But with the cable all the way in or out (disconnected and operated by hand) , then you hear some contact with the dogs, but no engagement in either direction.
Also, the shift rod is engaged with the part that moves it, and it travels between almost straight, to about 65/70 degrees.
wengr
Can an inability to lock the prop be caused by an improper (not in forward) position of the lower unit when it was mated to the upper? Maybe I should take the lower back off and do it again?
nola mike
Yes, but it should still lock in one direction at least. I'd take the whole drive off, and if it isn't shifting correctly then, split the drive.
flashback
What do you mean by "full engagement ". The prop will require a slight pressure on it in either foreword or reverse to keep it engaged.
wengr
I have been expecting a situation where when the prop locks - nothing but moving the shift cable will unlock it. Apparently that is incorrect?
Ayuh,...... You need to hold the lower in forward, when you slide it into the upper,....
