Amana Fridge
alldodge
The issue is the Fridge is not defrosting but I'm unable to find a defrost timer or heating element in the parts break down.
Model = AFB2534DEB
Labor day is the time to buy appliances and that's what we're going to do, but still would like to fix the issue. I takes about a month for the freezer cools to freeze up and I take everything apart and melt the ice off and start again
Can anyone find where the parts for this Fridge are located?
Defrost heater element?
redneck joe
There is another model that is same but ends with 13, is yours bottom freezer?
redneck joe
Tstat location
AI Overview
+2
Defrost Thermostat
The Whirlpool WP67003426 is a defrost thermostat found inside the freezer compartment of a refrigerator, specifically clipped onto the evaporator coil. To access it, you will typically need to remove the freezer's back panel. This component is a small device, about the size of a dime, that acts as a temperature sensor for the evaporator coils, melting frost during the defrost cycle to ensure proper ventilation and cooling
redneck joe
Element location
AI Overview
+4
Whirlpool WP67002493 Defrost Heater, Refrigerator
The Whirlpool part number WP67002493 is a defrost heater located inside the freezer section of your refrigerator. To access it, you will need to remove the back panel of the freezer compartment to reach the evaporator coils, which the heater wraps around
alldodge
Tstat location
AI Overview
+2
Defrost Thermostat
Thanks guys
Uses a element and thermostat
Might need to but the element and thermostat because one of the 2 is bad, and getting back in there again (third time) should have everything
