wvmedic
- Jun 3, 2008
- 542
Hello,
I have a 1995 E90TLEO Evinrude and have a question about the output charging volts.
I just got back from a remote Canadian fishing trip. While on the lake I noticed my analog volt meter was only reading 12 volts while running about 5000 RPM. I also noticed a clicking sound or what I thought was a clicking sound from the cowl of the motor. At that RPM it's hard to hear much...
So the next day running it I noticed that the analog volt meter gauge was creeping up above 12v and my humminbird graph was showing 12.2 to 12.5 volts.
I thought I remembered seeing nearly 13 volts on the gauge in the past and automotive systems charging at 13v or above.
Is this normal voltage? I know per my factory service manual it shows the voltage should be 12-12.4 at 5350 RPM minimum.
I would just like some advice from those with more experience than I with these motors.. Hopefully I was concerned over nothing.
Thank you, Jeff
Thank you, Jeff
