High Fuel Pressure
badrano
I've been running rich and did a pressure check and I'm running about 70psi at idle.
Trying to get a couple questions answered so I can just hop from one thing to another to get me through the diagnostics.
Last season I got the fuel injectors cleaned which apparently they needed it. 2 of the 8 had a poor spray pattern. At the time I had checked fuel pressure and it seemed ok but never to did get out to check it with the engine under load. For the rest of last season, everything seemed ok.
I've only used the boat about 4-5 times since May this year and the rich condition became more noticeable yesterday as it almost stalled out on me at idle and my fuel usage for the trip I took seem unusually high. When I got back to the ramp, she was smoking pretty good.
My next step is to check vacuum. If that's is ok, I'm going to assume I have a pressure regulator issue. I realized I have 2 regulators.... one on the rail and one on the cool fuel 3 module. How do you determine which regulator is the issue? Should I just replace both? This is a 20 year old boat.
Looking closer at the fuel module, it looks like I could get the regulator off using a wrench (no real room for a socket, especially for the bolt that's right under the edge of the exh manifold). But then how can I make sure I've torqued the bolts back down afterwards? Do I have to consider pulling the fuel module off?
I understand that my serial number falls into the range of the service bulletin for the paint issue on the cool fuel 3 modules.
Any other advice/guidance to resolve the high fuel pressure?
alldodge
The Reg on the rail does not actually regulate pressure, it's there as a damper, it try's to reduce the pulses coming from the fuel pump.
Make sure the Reg on the fuel module is not clogged up. It needs to be able to return over pressure back to low side of pump module. Needs a good cleaning
badrano
You just answered the general knowledge question I had.....How does a clogged regulator cause high pressure.
What you say about a clogged regulator is something I was wondering based other stuff I've read plus the fact I have the original fuel module.
badrano
Pulled the regulator off the fuel module. I don't have anything to compare to it to say whether or not it's significantly dirty or just a little dirty but there is definitely some grime on the screen.
Also, when I did pull it out, there was a string of paint hanging off the center part and across the screen....hard to tell if that was just from pulling it out or if the paint was truly blocking the screen.
Looking inside of the housing, looks like more paint might want to come off. The big question is do I try to scrape the paint out with a pick tool with the module still on the engine or should I pull the module off to really get a good working vantage point.
Or I see what looks like some type of repair kit - 8M0130861.
alldodge
I would remove to get a real close look at everything. Clean the entire unit and see if any other parts need to be replaced.
Did a search on the Regulator 892681 and was able to find for $107 and says it's OEM
Fuel pump
badrano
Fuel pump
Any thoughts on replacing the fuel module housing (8M0178981 / 892677) with the redesigned one so paint delamination will no longer be an issue?
alldodge
Depends on how well it can be cleaned
Lpgc
Just a side note, to compare how much fuel will flow through an injector at a certain pressure versus a different pressure compare the square roots of both pressures. E.g. If it's supposed to be 40psi but it's getting 70psi, square root of 40 is 6.32, square root of 70 is 8.37, 8.37 / 6.32 is 1.32 so the mixture will be 32% richer at the higher pressure.
kd4pbs
If the Mercruiser cooler is made of aluminum, I'd just de-paint it and use Alodine on all the exposed aluminum.
badrano
Interesting analysis. I know my wallet felt that 32% richer mixture. :)
Fun Times
Now you have to be careful that the paint didn't make its way to the injector....Again?... Also you may have to clean the inner fuel rail and the fuel damper on the rail (that's similar to a regulator) as you wouldn't want to lose it's needed performance... I believe you can open the one up on the rail and clean it without buying an over priced one from Merc or search out a similar GM auto one or search the Merc part number for a good quality equivalent match number wise online or eBay to find hopefully an AC-Delco or just as good… be careful of the $10.00 ones you’ll probably see in a deep search.
Up to you but probably better to try and remove the module to see if you can get a good cleaning out of it as even if you think you can’t get it all, then you’ll have to remove it to get a new one installed anyway.
The top cover “bottom side” and passages needs inspection and possibly cleaning as well if you give it try…. Regulator areas….
I could see a partially blocked regulator keeping the pressure around 70 as there’s been reports over the years of being as high as 100psi when fully blocked.
badrano
I popped the regulator off the rail, it was clean.
badrano
I guess I will figure out, but is it best to remove the fuel module by unbolting the brackets from the engine block or unbolting the module from the brackets. The side bolts are simple to get to, just not sure yet about the bolts on the back of the module.
badrano
Do I have to worry about priming the pump once it's put back on the engine?
badrano
Any special tricks to pull the fuel line out of the top cover? The pin screw is removed and the line does wiggle but it's not coming out.
alldodge
There is a quad ring in there and they can get stuck. All you can do is pull and wiggle.
badrano
Got the fuel module out minus a little slice on the finger. While tugging and wiggling, somehow my finger slipped off and I think hit a hose clamp and did a number on the index finger.
Is there a way to get pictures attached to this post because it will tell the story better.
Examining the top cover.....
- In the channel between the regulator and where the fuel rail line attaches, you could see the paint was not smooth and with a small pick and tweezers and following up with a brass tube brush, got all the paint out. I think the good news is that it didn't look like any missing specs of paint. What's left now is a paint free channel with a whitish coating. Not sure if this is some residue to the paint or corrosion.
- In the short channel that is the port that the high pressure pump feeds into to the channel that leads to the regulator and fuel rail, paint was bubbly and I removed it with a pick and tweezers. No missing specs of paint. Same whitish residue left behind
- In the regulator port, the only missing paint is what came out with regulator. The rest was scraped away with the pick and tweezers.....same whitish residue.
What is this whitish residue?
What can I use, something like brake cleaner spray, to spray in and around to blow away all the tiny tiny bits of crud? Also thinking of using q-tips maybe to get in there as well.
Should I consider buying the new and improved top cover for a mere million dollars?;)
Overall, the rest of the internal parts of the module look good, except what looks like a little build up of crud at the entrance of the one water channel.
alldodge
Pics won't work until someone with server access can fix it, and we don't know when they will do it. Load pics at a place like imgur or other and link here
The white stuff is most likely oxidation would most likely need a stiff brass brush type
If your going to use brake or carb cleaner all the rubber and plastic parts should be removed.
If you need a new top cover that's your choice
badrano
Finally got everything cleaned up and put back together, pulled a new vacuum line down to the regulator just for the sake of having a new line.
Fired it up and the fuel pressure at idle is right where it needs to be. The engine also just sounds better/stronger at idle.
Thanks for the all the help. This job was definitely the biggest repair job that I've done myself so far on the boat...at least from a contortionist perspective.
