5.7 Switched 12v
Galvez83
This question might seem crazy to some but i admit i am not a electrical guy. I ditched the carb after much suffering and installed a Holley Sniper 2. The wiring diagram requieres a "switched 12v red and a pink" to be run to the key. That is unreasonable on a 30ft boat. The question is, what wires can i use on the boat harness to feed these 2 wires. Is the purple that came from the coil an option or the carb choke wire? Engine model is VP 5.7gs PEFS.
Note....the Sniper 2 stays.
https://www.dropbox.com/scl/fi/anai...ey=hs42mqv1zxa6vz6762wegjd6z&st=ilrj64i0&dl=0
the purple wire is a switched 12 volt. that is the ignition.
you may want to understand the ABYC wire colors
good luck with your sniper.
Galvez83
Thank Scott,
Would it be ok to tie both wires to the purple? Or just one and hunt for a secondary ignition wire?
alldodge
kd4pbs
You may want to run the existing switched supply to a relay which is wired to a circuit capable of lots of amps. These ECMs can draw more current than your original ignition circuit is capable of supplying.
One word of advice switching from carb to a throttle body EFI: Do something about the exhaust crossover passage in the intake manifold. It is very helpful for carburetor performance and very detrimental to TB EFI performance. Some guys will JB-Weld the thing closed.
Donald0039
Did you figure something that stops the electric fuel pump if the engine stalls?
Galvez83
Good question, the engine stalled several times due to low voltage from the battery. I had connected the sniper to the secondary battery while i had the switch on the primary. Every time that the engine stalled (due to low voltage from secondary battery) the pump shut off with the engine. Not saying its a clear sign but the 3 times it did turn off, so did the pump and all related equiptment in the sniper. Took a minute to figuere out what had happened on a brand new Sniper but eventually i found the issue out.
ABYC and the Col Regs have requirements for either an oil pressure switch or powering the fuel pump from the alternator output.
What does the sniper have
Galvez83
Here is the breakdown,
1. Key-On Prime
With the key turned ON but engine not cranking, the Sniper ECU closes its internal “prime” circuit for about 2 seconds.
This drives the fuel-pump relay just long enough to pressurize the rail.
2. RPM-Dependent Run
Once you crank and the ECU sees a valid tach (RPM) signal, it re-energizes that same pump-relay circuit.
As long as the engine is spinning, the relay stays closed and the pump runs.
3. Safety Shut-off
If RPM drops out (stall or crash), the ECU immediately de-energizes the relay coil.
No relay coil → relay opens → pump stops
Galvez83
If anyone can advise what the correct idle rpms should be? Right now i have set at 800 when fully warm, i have a feeling its not right, as in too high. Not liking the loud clunk when going into gear. Any input?
