Ugly Impeller
tg3690
Put a new water pump kit on my motor last week. It has been about 3 1/2 years since I changed this one. It is by far the worst looking one I have ever seen come out of this engine. The book says to change it every year, some folks say it can go five years or so. I usually do it every 3 years. This one was about to self destruct. Glad I caught it in time.......
Factory impeller ?-----Or something else.----Sure looks like it was run dry a few times.
tg3690
It's the one that came with the kit I bought from MasterTech......I believe it is a GLM kit, with new housing, bolts, gasket, and plate. Doing spark and compression tests is the only time it was cranked dry. Never started the engine dry.
Joe217
Ouch,,,,,,,,,,, how was the shaft?
Joe217
I was working on the same thing on my 1986 85hp, 856x6l. The shaft had a grove right where the seal seats.......... made some steel shavings.........mix them with jb weld........ time will tell......... enjoy the pics...20250713_124602.jpg20250713_124710.jpg20250713_125858.jpg20250713_194227.jpg20250713_194200.jpg
tg3690
The shaft looked good. I was just surprised how bad that impeller looked. Most of the time they almost look good enough to reuse. But if I go to the trouble of dropping the LU it's getting a new one. (y)
jerryjerry05
That's nothing to worry about.
Some Mercury WP kits come with a rubber seal/boot that fits right at that spot.
cyclops222
Is every company making better parts ? And charging less money ?
Or are giant companies buying up everything they can ? Lowering quality and charging more ?
Free Enterprise. Sure is great.
Joe217
Your post got me thinking....... After checking around pics of the LU shaft I noticed that all of them have the same grove. I originally though that was caused by wear. As you stated....... that is where the seal seats......... Jerry, big thank you! I will now have to remove the JbWeld. Oops!
jerryjerry05
I had about 8/9 Forces with the groove in the shaft.
It never bothered anything.
Now a Mercruiser sterndrive?? It was so deep I had to seal it with JB or Marine Tex, Goop it up and put in a lathe and sand it down smooth. Lasted for ever.
