Mercruiser 3.0 1987 engine not running well after warmed up
alpha-newbe
Engine idles fine and will run smoothly at lower rpm in neutral and in gear. After running smoothly on the lake for 15 min or so at 3500 rpm then running for 15 min at 1000 rpm smoothly all is good. Then i go to running at 3500 rpm again and it runs rough so i back the rpm's down to 1500 again and it runs smooth. So then i just take if back off the lake because it is not running well.
alldodge
Might be a fuel pressure issue (pump or fuel lines) but when was the last time the carb was cleaned?
Have you checked the points and the dwell
alpha-newbe
Thank you alldoge! I currently have a carb rebuild kit and will plan to start there. Then fuel line checking and main fuel filter at base of engine. Already changed the small filter screen at the fuel inlet to carb.
alpha-newbe
New distributor cap, plugs, wires, condensor, and new rotor arm with gap set to Merc spec., ignition coil, and starter solenoid.
