VP 5.7 gsi - Temperature Rising
Wanna Tango
Hello All and happy 4th.
I have a 2000 Seaswirl Striper 2600 with a VP 5.7. I just changed the engine oil and filter, outdrive oil, fuel filters and took out the boat. Noticed that as soon as I hit 3500 rpm, the temp shot up to 250f. Dropped rpm and temp dropped. Took boat out and changed the impeller. Took out the boat today and noticed again that I hit 3500 rpm the temp climbs but at a slower pace than before. I also noticed exhaust / smoke coming out of the outdrive.
Thinking of changing the thermostat just in case but not sure what else can be the issue.
Any help or direction will be greatly appreciated.
alldodge
VP so you have a crank driven water pump, correct?
Have a serial number?
Are their any grooves on the wear plate or pump housing?
Wanna Tango
Here is the number 401203969
When you say grooves on the wear plate, where would I see this? Do I need to take off the pump?
By the way, I am fairly a newbie. Lol
Check the pump housing for grooves/wear marks
Verify the raw water fitting on the drive isn't damaged
Wanna Tango
Update post: I pulled the water out of the water since I have it dry docked. All looked ok with housing but when I was flushing the engine, noticed quite a bit of exhaust coming out of the outdrive. Thinking I need to take it to a shop for diagnostic and then see.
Unless someone here has any ideas or troubleshooting fixes.
alldodge
If motor was running you should see exhaust coming out of the drive.
garbageguy
Rust and stuff in the cooling system? The risers on my "VP" V-8 had some in there when we put a new long-block in there a number of years back. After they were cleaned-up and reinstalled, the cooling-system in that boat worked great for quite some time.
Wanna Tango
I put new manifolds and risers in last year as well.
replace if its corroded.
they last at most 3 years.
Wanna Tango
These fittings are on the drive under water. Nowhere near the thermostat
Hi Scott, I realized now what you were referring to and yes, the first fitting is what is on my outdrive. I did see that the fitting was cracked, so I suspect that is where there was not enough water coming in at higher speeds. I pulled the outdrive off and the drive & the pivot housing are corroded together. I started another thread for this issue as I am not able to separate them.
Thanks for letting me know where to look.
