frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 506
Good afternoon,
06 Yamaha, 70hp, 70TLR (prior numbers/letters ripped off sticker)
I am having difficulties removing a prop shaft. The water pump base plate had corroded so bad that it broke apart and the base is level with the lower unit surface so it has to come out. I typically pull the hub and the shaft slides out after the shift rod is removed. It appears that the thrust washed is stuck and will not budge. There was corrosion around the O-ring and suspect it creeped at the thrust washer edge where it meets the housing. Is there any ideas why it is not coming out? I have a little over an 1/8th play when I pull the prop shaft and can get just behind that. I've tried heat and a little tapping with a hammer along the outside edge of that washer. Not sure how to proceed. My manual goes up to '04 but I do not have one for the '06. Assistance would be real helpful..
