Setting engine valves
lonewolf41
This is for a 5.0Gxi motor. Typical 305 Chevy vortec engine. I am setting the valves after a rebuild. I have seen (including different posts here) 1/4 turn, 1/2 turn to 3/4 turn, and the volvo manual says 1 full turn past zero lash. Any consensus as to the "correct" adjustment?
Lou C
When I did mine I used one turn as per my OMC Factory shop manual. The tricky part is finding zero lash first…
If it's vortec, it's not adjustable unless there is aftermarket valve train.
If it's adjustable valve train, then between 3/4 and 1 turn after zero lash
lonewolf41
Yes, it has hydraulic roller lifters. Went with the manual and what seems to be the more popular option and set them at 1 full turn. Thanks for the help.
Are you sure you have adjustable valve train?
Lou C
My 4.3 had the roller cam & adjustable rocker arms…
4.3's had rollers from 1988-1995. the V8's didnt. starting with the vortec heads, GM went with non-adjustable valve train.
Lou C
Odd thing is if I wanted a reman 4.3 from 87-92 which is my casting number series, Michigan Motors sells them with only the flat tappet!
ScottinAZ
Master Chief Petty Officer
the 4.3 in my 95 has a roller cam, but does NOT have adjustable rockers.... run them down and forget them.... and despite the valve covers, this one is pre-Vortec.
ScottinAZ
I'm not sure what besides the lifters would make them adjustable. The lifters are hydraulic and compress while doing the final 1 turn.
old school Chevy engines had a stud, rounded fulcrum washer and locknut. You set the preload on the lifter by cranking down on the locknut, but it never bottomed out, it balanced between the valve spring tension and the lifter preload. if a lifter was a bit noisy, you had a measure of adjustment with that style of setup. Newer engines have a bolt and a positive stop you run down to, there is no locking and no adjustment available on them. set em and forget em.... easier for assembly line monkeys to do quickly......no way to compensate for a slightly out of spec part though......
