No start after engine install. Need Help!!!
jonny rotten
Need help!! Video I pulled a motor 6 months ago for an oil pan leak. Was running perfect when I pulled it out. Kind of proud of myself for doing every single thing myself and now I might have to send this out over something simple. Won't even hiccup with ether. What I know: 12 vts at purple coil wire. I took a timing light and put it on the coil to distributor wire and got nothing. Coil has 1.3 primary 7.85 Secondary. Previously there was a jumper bypassing the oil sender/ switch (forget which one is which) I replaced both sender and switch down by the oil filer with new OEm parts. Now the oil pressure gauge is pinned and there is a constant alarm with key forward. Merc says there is an oil cutoff that kills power to coil?? I put the jumper back for testing and still had a no start with alarm. I have 9 volts at the blue wire at the push on terminal sender switch. I think I got all grounds. Shifter cables disconnected and cutout is centered. Lanyard in run position. I also disconnected bullets at shift Interrupter for testing at that did nothing. New cap rotor wires plugs...any help with this is appreciated. I'm Not great with electrical...really want to figure this out on my own and complete my project. Thanks
  • 20250519_143019.mp4
Scott06
Wi
Need help!! I pulled a motor 6 months ago for an oil pan leak. Was running perfect when I pulled it out. Kind of proud of myself for doing every single thing myself and now I might have to send this out over something simple. Won't even hiccup with ether. What I know: 12 vts at purple coil wire. I took a timing light and put it on the coil to distribute a wire and got nothing. Coil has 1.3 primary 7.85 Secondary. Previously there was a jumper bypassing the oil sender/ switch (forget which one is which) I replaced both sender and switch down by the oil filer with new OEm parts. Now the oil pressure gauge is pinned and there is a constant alarm with key forward. Merc says there is an oil cutoff that kills power to coil?? I put the jumper back for testing and still had a no start with alarm. I have 9 volts at the blue wire at the push on termininal sender switch. I think I got all grounds. Shifter linkage disconnected and cutout is centered. Lanyard in run position. I also disconnected bullets at shift Interuptor for testing at that did nothing. New cap rotor wires plugs...any help with this is appreciated. I'm Not great with electrical...really want to figure this out on my own and complete my project. Thanks
willing to bet during cranking you are loosing voltage, start with positive battery and ground cables.ther are 2-3 at the back on flywheel cover
Measure with a volt meter on positive terminal of coil while cranking should stay close to 12. Then go through the thunderbolt ignition troubleshooting guide in the stickies.
From what you are saying the coil is not firing? Willing to Bet missing a ground. Also disconnect the shift interrupt switch for testing
Scott06
Wi
the oil pressure alarm doesn’t interrupt the ignition. It just makes the buzzer go off when below 4 or 7 psi.
jonny rotten
Wi
Ok. I'll leave the shift interrupt connections off until I figure it out. There are 3 or 4 grounds on the port side engine stud in the back and one on the starboard side. I took pictures before I started. Those are all on. What ground would cause no spark at coil? Where would that be? Good to know the oil sender/switch will NOT cause a no start issue. I'll cross that off. I'll check the 12 volt at purple wire + while cranking and see what happens
alldodge
Something is not connected correctly
What is your motor serial number?
alldodge
Motor has TBV ignition
Make sure 12V remains when cranking and if it does
Run the TBV troubleshooting
alldodge
Looks like you have corrosion and/or weak Bat, At 11.85 it's around 40% charged
Fully changed Bat is 12.7V
jonny rotten
I found this ground wire and couldn't figure out where it came from. It does have the same size ring terminal as the coil post. Is that supposed to go on the negative post of the coil? Not sure if the wire is even long enough to reach coil. I put it on the starter solenoid bracket. It was NOT there before I started looking at an old pic. It comes out of the harness where the starter solenoid wires come out
jonny rotten
In the video you can hear it cranks really strong. Does the drop from 11.85 to 9.54 on the coil when its cranking tell you anything?
alldodge
Yes it says there is corrosion and the ignition is not getting enough power
Take voltage readings at Bat post
jonny rotten
I did. I posted it with the coil numbers. Battery is 11.95
How does the main module on the riser ground? Is that though to the riser or within the wiring harness? Could that be a potential issue?
alldodge
All grounds should be well grounded. Don't know if the bracket were the black wire is connected has a good ground or not. The wire might be for a Mercathode which doesn't look like there is one,
What we know
Voltage is low
There is no spark
Need to run through the TBV troubleshooting
jonny rotten
What we know
Voltage is low
There is no spark
The only problem with that is it starts with tach wire which is taped into the entire wiring harness from the engine to I assume the tach. I would need to take the whole thing apart which seems like it could cause more problems for potentially nothing being the engine ran fine before. I used Deoxit on the grounds, power at starter, electrical connections ETC trying to do it right. Deoxit supposedly is good stuff for electrical connections. I'll charge the battery but feel like thats not it. I've started engines with way more dead batteries.
Scott06
Disconnect the tach wire (grey) at negative post on the coil. This will remove any chance the tach is killing the spark
you can also disconnect it and check for continuity to ground with a volt meter.
woukd agree battery and connections both positive and negative are suspect given the voltage drop
