Bought Boat and Steering is locked up
Tinjum
Steering Wheel is stiff and wont move besides slightly, I undid steering bar on motor and the motor moves freely, Think i need to take apart the steering gearbox or think i need to replace the cable?
Outboard steering cables often stick at the engine. Undo the large nut holding the cable to the tilt tube and then turn the wheel. If the wheel and cable insides move freely, you need to attend to the steering rod inside the tilt tube.
Mc Tool
Ensign
get a replacement helm and cable.
See this is part of the reason dealers are loosing to the internet.
FFS Scott ,telling somebody asking for help to just replace the whole system before finding out what is actually wrong is just bollocks , shame on you .
Tinjum, I have just made myself a pusher ( not really a puller ) to push my steering cable end out of the tilt tube from whence it is stuck ( again , must check the o ring seal ). I would be happy to post pix if you want .
My set up is a pita ,I cant remove the cable from the tilt tube with the motor on the transom so I unbolt it and hang it off my engine crane ( dont need to disconnect wiring ).
Last time (3 years ago when I bought the boat ) I beat the cable out with a soft dead blow hammer ,this time I have the pusher and hopefully a bit more finesse.
Obviously there is water getting in some how which I will have to fix. 🙂
Steering cables and helms last about 15 years, then the cable wears through the inner liner of the sheath.
Any repair is just a bandaid
Mc Tool
Ensign
Psychic too Scott ?
No mention of age in op , nor any indication of actual usage.
If the cable has worn thru ( as you guess ) why does the helm need replaced ?
If the cable inner has worn thru ( how would you know ) simply loosen the cable outer at both ends and rotate about its axis ½ a turn and re-tighten ends and get another 15 years .
One thing I see a lot on US websites is a lot of peeps dont do any actual diagnosis just take a wild guess and throw parts at it until it works again ( or not ) without ever finding out what was actually wrong .
redneck joe
In dad's 1979 SRV searay with 140 johnson had a rack an pinion steering. A tooth broke out. I got to steer a v4 for about 10 miles...
Last two helms I swapped, not even a 3" bore hydraulic cylinder at 3000 psi could budge the core in the sheath. That is 21,000# of force. Rust is strong
Mc Tool
Ensign
Yeah well your not wrong about that , I just went out and give it another whack with a copper hammer and it feels welded in there.
I forgot to get a pic of my pusher .....maybe tomorrow 🙂.
Tinjum
Would absolutely love some pics, also dont have room to take cable out of tilt tube without taking motor off. Although, have unscrewed it, a little stiff but does move freely when not on tight.
jimmbo
Huge Quantities of Penetrating Oil, and some Heat may be needed to remove it. A Passage Brush should also be run through the Tilt Tube to clean it out. Sometimes the Tilt Tube will also need to be replaced
Mc Tool
Ensign
Yeah I think I will get a new tilt tube this time round
I ruined 2 x 20 bore shotgun bore brushes cleaning it out last time and used it twice ,sat for a winter in a shed and now seized again
Huh , the tilt tube nuts /thread is â…ž" unc , I thought it would be metric coz everything else is.
dubs283
Well, the internet warriors have lined up here so I'll add this:
Scott is absolutely, 100% correct in suggesting OP needs a complete new steering system from helm to motor. Often times, with a locked up cable/helm one will find the steering system is far older than its serviceable life and does require a complete replacement. Most often the locked up system is so old that multiple generations of changes have occurred rendering the components NLA for quite some time
The number one reason, aside from NLA components is safety. Imagine cruising along in your boat, on step at 35-40 mph with your freshly repaired antiquated steering system and something lets go. Very scary/unsafe conditions. A system that's locked up can just as easily break at any time
A sound steering system on a boat is just as if not more important than a sound braking system on your automobile. There is a reason mercruiser does not sell rebuild kits for their power steering actuators, the liability factor is much too high
Dub, you do realize that the steering rods bind in the tilt tube far more often than they fail?
I think it worth a look, as it would only take .05 worth of grease to fix it, once it is loose.
Of course it will take a can of penetrating oil, a pipe wrench, an hour and some rags, plus maybe a torch to get it loose!
eggs712
I have unfrozen several cables by attaching ATF-filled clear vinyl hose to the end of the tube. With the hose pointed up so that the fluid enters the tube, rig the other end up to compressed air. It sometimes takes a week, but it works.
