ratdude747
- Sep 30, 2023
- 482
This is something I noticed last season (my first season of owning a boat)... it seems I had to run the idle awful fast on cold start.
Engine is a 1976 Mercruiser 888 (302) that has been swapped to a Holley 4160 (4 barrel) marine carb.
It would only start if I gave it enough throttle to get up to 2000RPM... and wouldn't stay running at actual idle until a couple minutes after. Once warmed up, it was fine. The boat's manual shows that some amount of throttle is needed to cold start (simulate what a fast idle cam does on a car carb)... but is this excessive?
I had the electric choke tuned a bit rich to help... which didn't. I then reverted it to "neutral" adjustment (when cold, just enough tension to close the choke) which still didn't change things.
My concern is blowing up the impeller since I did fry one last spring by running it too fast on insufficient muffs, but that was 3000RPM or so. On the last outing of the season I didn't overheat, so presumably my impeller is still good, but before I do my first test firing on muffs this coming week (or even tomorrow if the rain stays away), I'd like to make sure there isn't something else I need to check... and I really don't want to blow the impeller. I may do the dish soap solution down the impeller hose trick... still...
I'll note that it didn't do that on muffs last spring. But it did do it every time I was was on a lake/river.
