- Jul 23, 2011
- 52,080
your manifold is drilled for dual patterns..... Holley Pattern and Q-jet pattern
Right on. Would you keep one or both of the spacers on there or take them all off?your manifold is drilled for dual patterns..... Holley Pattern and Q-jet pattern
This is an inboard tournament boat that's why I'm curious about it.I was going to say. The only time I even remember seeing the wedge spacers on the mercs was on the inboard setups. If you look at the angle they're mounted at it makes total sense why. I never saw a wedge in the parts break down for an I/O... Spacers and adapters? Yes but no wedge.
I'd still not worry about it. Set the carb up read the plugs after running around a bit and see if you can get it to act up. If not, don't worry about it. From the photos, your engine doesn't seem to be at an insane angle or anything hence why I missed it was a straight shaft.This is an inboard tournament boat that's why I'm curious about it.
Sounds like a plan. Once I get the right carb studs I'll post a new thread for help to set it all up. Do you think I should ditch one or both spacers or keep them?I'd still not worry about it. Set the carb up read the plugs after running around a bit and see if you can get it to act up. If not, don't worry about it. From the photos, your engine doesn't seem to be at an insane angle or anything hence why I missed it was a straight shaft.
i just punted on serial number/year but it does show a wedge used with the weber carb.This is an inboard tournament boat that's why I'm curious about it.
So your saying keep the large plastic spacer and get rid of the small metal one? Slap the 1409 on that? Or just slap the 1409 on what is sitting there now and try it out?the fastest will be to swap the AVS for the 1409 as it sits. read the plugs. from there loose the one thinner spacer.
I wouldnt worry about a wedge spacer unless it bothers you.
