mercruiser 4.3 thermostat housing
ste80
Hey guys double check me
These Serria wires are 8MM and silicone jacket and should work on the motor
WIRES
hi sorry for delay, but this month i'm abroad with limitated acces to internet :(
thanks for the feedback, so you think the lenght is not an issue? this would be a grat things so that i cold by all there
thanks
alldodge
thanks
They are marine so will be long enough, the question is do you have Delco EST or TBV distributor? I'm pretty sure they both use the same wires, but not positive
ste80
ste80
thanks, i didn't see from the phone the message of the sierra so this is why i was not understanding , and now when you said marine i thought that there was something missing :) i got it now tks
just thinking what else i could buy from there and i will proceed today or tomorrow.
Scott06
i
but in your opinion what is the difference? i can not see any
in the applications part 18-8835-1 fits Delco EST and YEMS distributors
where 18-8810-1 looks to fit both Delco EST and Thunderbolt distributors.
One would think there is some sort of difference if they are making two parts numbers.
Do you know what distributor you have ? if you take a picture of it probably someone can tell
alldodge
8810 fits TB 4 and 5 along with EST and has all 90* (pic) plug boots
8835 fits EST (most likely also TB) and has mix of 90* and 45* plug boots
IMO they will both fit
ste80
Someone know instead wich joint is this one? ( Alpha one gen2) Without greasing i sow they are selling on summit so i will buy this too
Scott06
if you have the inside snap rings MOOG 315G or equivalent This looks like what you have but cannot be sure.
if you have the external snap ring moog 344 or equivalent - which I think cross references to a volvo 240/740/940 among other vehicles
ste80
I think internal , should be here (red circle) but mine is not grasable
alldodge
sure i will but i need to buy here on summit they do not have
Yes they do 18-5274
Summits search function its very good. Easiest way to find these kinds of parts, is search the web and find the part. Then go to Summit and enter the part number
alldodge
got it should be SIERRA-18-2097 or mercruiser 805536A1
These are correct for the inner clips
These are my notes
1-6301DL Autozone (Alpha)
805536A2 permalube – Sierra 18-2097
Greaseable older Merc 75831T1 , GLM 8030 at Mercstuff, Sierra 18-2174
Scott06
ste80
