2000 Johnson 70 j70plsis
tkdrumr
I just picked up a 2000 Johnson 70 hp outboard from Marketplace. The seller was very clear, it overheated and one cylinder sleeve has rotated out of position. That's OK, I bought a short block the day before and wanted this for parts anyway. So, I decided to take it apart and split the block to see what it looks like.
Here is a picture of the middle cylinder - the one that rotated as you can see. There is what looks like a gouge on the end of the port. It almost looks like it was done in the machining. Any ideas what this is?
The only other damage I saw was the top cylinder was melted a bit and there was some aluminum on the wall. I'll get pictures of all three pistons and cylinders. I'm considering attempting to reposition the sleeve, run a hone, put in a new piston (I have one available), put it together and run compression and leak down tests on it.
Faztbullet
Someone cut that or came from factory like that. Sleeves are installed/straightened and block is drilled in middle of transfer port webbing. It is only drilled deep enough to dimple the sleeve and a set screw is installed and epoxied over
What item # is 350943 and on what parts page ?-----To me it looks like it was machined ( error ) and let go by inspection.----In 2000 there were issues with OMC as company was in trouble.
tkdrumr
When Faztbullet posted the comment about pinning the cylinder, I searched and found that item. Looking again, that part is in the exhaust housing. Your assessment is what I was also thinking.
tkdrumr
Thanks for the description. I picked up this entire outboard and controls for parts, so I'm not sure if I'll have the PH fixed, hold it, or sell it. Maybe I'll drop it off at a machine shop and have it assessed.
