Ice Maker Identification
sonicfog
Does anyone know what brand/model the ice maker the red arrow is pointing at? Thanks
Fun Times
Have you had a chance to image search marine ice maker brands for boats? There are a few that appear close to your design except for the upper shelf type handle, other than that, the U-line brand found at places like West Marine seems close but so did one from Isotherm.
By change, is there any model names/stickers, etc. type info say inside the ice maker?
What's happing with the one in there now?
sonicfog
I can't find any brand name. Im guessing the label is on the back. It's stopped working. I'm considering buying the boat, maybe replacing the ice maker or replacing it with a freezer or fridge
There's already two fridges on this boat, cockpit and galley, so... not sure what to do.
Fun Times
If it’s not making ice due to water flow then maybe it’s something such as a clogged water line, filter, brittled up water line causing leaks or air to the maker.
On boat types such as those, should the original owner still have the all the paperwork from new, sometimes mixed in is the build sheet from new and may mention the name brand and or model number for items such as those… You might get lucky that way at finding something.
Another option to investigate would be trying to remove the lower air vent cover to see if your phone video camera picks something up somewhere info wise if you don’t want to try removing the maker right off the bat.
Maybe look up the general costs of a measuremented size and mention you’ll probably replace it and offer either the full cost or go in half with them off the overall cost of the boat if it’s a deal breaker, etc..🤔
Hope the deal goes easy for you and nothing serious with the ice maker, good luck with the boat buy and new to you boat should everything align in your favor.🙂😎👍
