Have spark and fuel, can't get the rebuilt engine to start
Theom
You've all helped me get fuel and spark, but I can't get the engine to start now. The machine shop installed the internal moving parts, I put everything else on and installed the engine.
Spark: Most recently I verified cylinders 1 and 2 are sparking by setting the spark plug and wire against the block and turning it over. Both have an obvious spark and the plugs look nice and clean. All the spark plugs wires are now and I went through and double checked they're all routed to the correct cylinder.
Fuel: When I pull the fuel line right after the fuel pump off and turn it over, it's obviously squirting gas out of it. When I press down on the accelerator pump on top of the carb it squirts gas into the carb out of both sides under the choke plate. I think this means I've got fuel getting up to the carbs.
Timing:
1) Finding cylinder 1 TDC:
I found top dead center of the compression cycle by attaching a compression tester to cylinder 1 and then manually turning the engine over until the PSI popped up on the pressure gauge. Then I looked through the spark plug hole while turning the engine over manually until I saw the cylinder stop moving upward and marked that spot, then kept moving it until it just started to move down and marked that spot. I used the center between where the cylinder stops moving up and starts moving down as the TDC
2) Align the distributor: I rotated the distributor shaft until it pointed towards about cylinder 1 on the engine because that's where the #1 terminal for the distributor cap was too. Then I rotated the housing until the housing and cap were pretty closely aligned to where the rotor was pointing.
3) Adjustments: After it wouldn't start, I tried using the timing light to set it to 8 degrees before top dead center, but I realized at starting RPM's the mark is in quite a different spot than what it would be at idling RPM's. I then tried rotating it back about 4 degrees at a time for 24 or so degrees and when I'm at about 14 degrees before top dead center at starting speed (not idling speed) it gives the most signs of life but isn't starting.
It seems like I'm getting fuel and spark now, so my assumption is that my timing is off and I just can't figure out how to get everything firing at the right time to get started. I've tried spraying starter fluid into the carbs and pouring 2 oz of gas into the carbs and can't get it to start.
Any help and ideas about what to do now to get it going?
Bt Doctur
Not knowing the engine your working on so:
v6 165432 clockwise
IL4 1342 clockwise
v8 1,8,4,3,6,5,7,2 clockwise
Verify TDC compression again for #1 , where ever rotor is pointing call that #1 cylinder ,install cap and wiring accordingly
Scott06
Timing:
Verify the firing order and that you are timing it on tdc of compression stroke vs tdc of exhaust stroke.
loosen distributor and turn it while cranking to see if you can get it to stay running
Gee, if it won't fire or backfire with ether, the spark is way off. You might pop off the valve cover for #1 cylinder and verify the valves operate properly, and you are installing the distributor so it fires on/near TDC on the compression stroke.
Not an expert here, but is there a mix up with left hand / right hand rotation parts ??
alldodge
There may be spark but it's not enough to ignite the fuel.
Get a spark Gap Tester and connect to coil
Has TB ignition, can also run thru
nola mike
I'll throw in here as well, since we don't know the specifics of "won't start" (unless I missed it). Is it catching/back firing/etc? If it wants to start until you let off the key, it's worth checking that you're getting 12v to the coil with ign on. The cranking power circuit is different than the running circuit.
Theom
I rechecked that it's on TDC on the stroke that generates compression pressure in cylinder 1. Using a compression tester it only triggers a jump in PSI every other manual rotation. On the cycle that generates pressure I rotated it to TDC. I rotated the distributor cap so the rotor is pointing at the # 1 plug.
I double checked all the wires are going to the right cylinder.
I bought a spark plug tester. Here is the video of the results. Sound on if you want to hear how the engine sounds. I set the gap on the tester to 10mm and it looks good to me.
  • PXL_20250111_060246993.mp4
Theom
I rotated the distributor cap about 45 degrees clock wise and counterclockwise from the starting position. When I got counter clockwise 45 degrees so the #8 plug is where the #1 was, it showed some signs of trying to start. Video attached.
  • PXL_20250111_062943527.mp4
04fxdwgi25
Camshaft to piston TDC is correct ?
Hmmm. Wonder if timing chain is timed correctly between the crank and cam. Something is not installed / timed / adjusted correctly.
If everything is timed properly and valve lash (rocker arms) are correct, you should have fire.
stresspoint
your timing is off by 180 , take the rocker cover off the #1 cylinder side ( most forward cyl is #1 BTW).
set the valves so the springs a full expanded on both valves , this is now compression stroke ! .
remove the dizzy completely from the motor , put a paint mark where #1 lead is on the dizzy body .
put dizzy back in and make sure it drops al the way down and the rotor stays at the paint mark as it aligns with the oil drive key .
pull all the leads from the cap except #! and start one by 1 to put them in the correct direction on the cap and to there respective cylinders .
motor should start , have timing light at ready hooked to #1 plug .
dont forget the jump wire , it needs that to set the module ( google that )
set the timing to speck and take that motor for a good run in.
probably missed some steps but this is a basic run down to get everything set tp make it go .
Pull your distributor, turn the motor over 1 revolution. Reinstall
cyclops222
Are we positive the camshaft is timed correctly to the crankshaft and # 1 piston at TDC ?
