ROBJABLONSK
Thread starter- Joined
- Oct 1, 2024
- 5
I've replaced my water pump twice and engine is still overheating. I get tons of smoke/steam out of the pee hole and when I shut down the engine it puffs out a huge cloud of steam/smoke. See photo. I suspect the exhaust plate gasket is damaged right where the copper tube slips into it's home, the sleeve at the base of the exhaust plate. I do get a little water out the pee hole when I start the engine and run at low RPM's. But if i run at a decent speed, it turns to a spray of fine mist, probably steam.
I do not have any leakage from the power head. It is dry and solid and looks like new.
To test the water flow through the powerhead i connected a garden hose to the copper tube with clear tube and hose clamps. I turned the water on low flow and I get tons of water coming back at me down through the cavity in the mid section where the exhaust tube and drive shaft are housed. I also get water coming directly down through the exhaust tube. See pictures. Eventually a stream of water starts to come out of the pee hole. However most of the water is coming back at me down through the cavity in the mid section of the outboard and exhaust tube. Seems like the water is leaking back from the exhaust plate into the exhaust tube and the drive shaft cavity. Which would mean the gasket on the exhaust plate is bad?
