Water plumbing system
rickasbury
Master Chief Petty Officer
Our express cruiser has a water system for sinks/little shower etc...stopped working. Pump is probably 4 years old, not used heavily.
I turned the switch on and probed the two wires going into the pump and does not seem to be getting power. I pulled the panel off and oh my- I expected a simple rocker switch with 3 wires- not so! What do I do with this? I was going to jump the switch to check it but like 6 wires?
Recently the control gauges(temp, oil pressure etc) were stolen its on a different panel- but they tried to steal both. Would you think there is another plug in the harness lower and Mayne got pulled? How do I test/jump this switch?
alldodge
Steeling switches? that's bad as well as different
The 6 wires I would expect in and out wires
2 ea 12V in and goes back out to other switch
2 ea ground in and goes back out to other switch
Might be only 1 going to pump but looks like 2
rickasbury
Yes, some crack head tried to steal all the gauge and switch panels- it was a mess to get straight.
