68glasspar
- Aug 28, 2024
- 112
I checked the compression and all were 110 to 120psi. I checked the points and had champion plugs in it. I have switched to ngk and that didn't help. The engine just isn't getting to full power and then after a little bit it will start cutting in and out. Its like a fuel restriction or running lean. I ordered a new fuel pump for it. Anything else to look for?
Can an old fuel quick connect let air in the system?
