Johson outboard starter
PrincessAnk
I have a johnson meteor 100hp motor. The plate on motor says it's a v4ml-12r and I am trying to locate a starter fully assembled not parts for it. Mine is dead. The starter has a model prestolite mgd-4001-12v and I do Google search and so many different ones pop up but not looking like mine I got. Hoping I can get some help. I really wanna get this boat in the water.
saltchuckmatt
There's a few guys on here that might help otherwise I'd try these people.....AOMCI
Rebuilding's probably the only way you're going to get it though
Gear on the armature broken ?-----Need the separate bendix parts too?----Your location ?
How did this motor run for you last season ?-----Tried jumping directly to the starter ?---Bypassing the safety switch ?
PrincessAnk
Yes and the boat is a project boat. It was turning over before then just died. And yes did direct jumping. This is a old motor and hasn't been worked on in years. I'm trying to get it going again. Just got a new wire harness for it and spark plugs and wires and ya.
Friends of mine had one of these motors on a 17' deep V boat.----Skied many miles behind it.----Used to pull 2 skiers out of the water with slalom skis.----A real powerhouse.----Take starter apart for inspection.-----See what it needs.
cyclops222
Have you measured the battery voltage while jumped on the starter ? could be worn brushes stuck in the brush holder.
