- Mar 8, 2009
- 44,330
Going to discuss prop selection using Mercury scanner with new Verado 250hp OB with DTS
Props - Merc Rev 4 19 pitch
Hey @muc help keep me straight
Thought about putting this in the prop section but this is about how to determine which prop should be used based on Merc data.
I'm using the Techmate Pro and would be easier using Diacom, but it is what it is
First run today Saturday Labor day weekend, note: best not to do this on holiday weekend.
Was watching Demand Linear (DL) and Demand Guardian (DG), and that was first mistake. I should also have watched "Demand".
Watching DL I see the TPS is at 100% so the throttle is at WOT. Trimming up or down in real choppy water is not giving me a good indication that full power is being applied to the prop. Seeing DG is at 0% so guardian appears to be not in play
Max RPM is in the 5800 range, even when I trim up above what should IMO be max. So is there another guardian issue not showing on the Techmate or something else. Need to test more and watch Demand
