Jamesaelliott
Thread starter- Joined
- May 10, 2021
- 37
It’s a manual start, single carb. This thing fires up and runs great at idle, as soon as I put it in gear it bogs down under acceleration. Here is the list I’ve done. Cleaned carb about 10 times, replaced fuel line, prime bulb, filter and pump, bypassed the fuel connect at motor. The primer bulb stays tight, Compression is at 120. Checked spark with spark tester. Spector fuel tank is 11 months old. I have noticed that my vent is not working, it’s not pressuring up during the hot days, it’s actually kind of sucking in a little bit. I don’t really see it being the vent causing my issue but I could be wrong. Any other suggestions?
