mrboatman3354
Thread starter- Joined
- Aug 6, 2024
- 2
Intermittent bog at full throttle
Hello! I have a 1999 40hp 2 cycle Mercury 3cyl. Very periodically I will all the sudden completely loose full throttle. During these times where this occurs the engine will misfire slightly and run not so great at lower speeds too. It's like a light switch that is entirely unpredictable.
I ran the boat for 3 days straight with no problem, and then boated across one of the largest inland lakes in Wisconsin, on my way back about 400 yards from the boat launch it happened just like that. I've replaced the fuel pump, fuel lines, fuel tank, and spark plugs to no avail.
It will always, except when the issue suddenly occurs at full throttle, purr like a kitten and runs great. It has good compression and oil consumption rates. My only two theories at this time is that one or more of the coils are starting to breakdown and it only is an issue when warm, or that gunk is in the float bowl that only periodically causes an issue. Any thoughts? Just need help with direction at this point.
*Note: problem seems very similar to when you forget to open the vent on your portable gas tank. I've checked it when this occurs and it's not the problem*
