O2 Sensor codes . . .
tpenfield
I've been getting some O2 sensor faults on my port engine, and it looks like I don't have the proper 'Mercruiser PCM 112' manual to get more information & trouble shooting. The engine manual does not list the codes and refers to the PCM manual :unsure:
From my Diacom Software, I am getting:
Fault Code: 871
Fault Type: 24
Code Desc: O2 sensor starboard S2
Type Desc: Input from sensor is above valid limit
Fault Code: 872
Fault Type: 16
Code Desc: O2 sensor heater starboard S2
Type Desc: ECU problem outputting signal to device
Engine is Mercury 6.2L DTS EC S/N 2A458510
I cleared them a couple of weeks ago, but they have come back.
I would like to get a better understanding of the codes before I load up the 'parts cannon'.
@muc ? @Fun Times ? Others ?
T.I.A. :cool:
muc
check for 12v on orange/black wire at position D at sensor
then check for ground at the other orange/black wire at position C
do these checks with engine running soon after starting.
This is what the manual recommends.
Unplug and replug the sensor, check the fuse, swap sensors. Note; must use another post cat sensor -- pre and post are different.
Fault Code: 871 -- O2 sensor starboard S2 (postcatalyst)
Fault Type: 24 -- Input high
Check the PCM‑to‑sensor circuit. To diagnose, replace
the suspect sensor with a known good sensor, or switch
the port and starboard sensors to determine if the fault
follows the sensor.
Fault Code: 872 -- O2 sensor heater starboard S2 (postcatalyst)
Fault Type: 16 -- Output fault Check the fuse and PCM‑to‑heater circuit. To diagnose, replace the suspect sensor with a known good sensor,
or switch the port and starboard sensors to determine if
the fault follows the sensor.
You should get a copy of the manual #8M0109714
Lots of good info!
tpenfield
Thanks @muc . . . Looks like I got to get one of those O2 sensor sockets to do the swapping.
In my engine voltage efforts, I did have an issue or 2 where one of the 10amp fuses got knocked loose. I'll have to check those again.
7/8" box wrench or deep well socket and a cut-off wheel if you don't have a band saw
tpenfield
Thanks everyone for the help on this. Looks like I'll be buying the special socket and swapping left & right to see if the problem moves with the sensor.
Lpgc
Fault Code: 871
Fault Type: 24
Fault Code: 872
Fault Type: 16
T.I.A. :cool:
Those 2 error code descriptions combined often point to the probe's heater circuit being shorted to its signal output, a problem with the probe itself or its wiring, in which case changing the probe (or fixing the wiring issue) is the fix. Good idea to swap probe positions to see if the error codes follow the probe.
tpenfield
Just getting back to this thread with some follow-up. . .
I replace the sensor (post CAT) and it is all good. The sensor was pretty much disintegrated, which leads me to think that the other sensors may need replacement soon. :unsure:
The Post CAT sensor is about $60, but it looks like the Pre CAT sensors are $200+. If they all need replacement soon, I'd better start saving up my weekly allowance. :LOL:
