84 Evinrude - Balky High Speed Operation
ddonald
Our houseboat was powered by a 90 HP 1984 Evinrude. The powerhead went recently (badly scored cylinder walls and piting/burning of cylinder head) Just prior to this, the engine would hesitate (balk) at high speed.It would run at high, then rpm would reduce. I inspected all fuel lines, cleaned filters. Also have a glass water separator in the line. I cleaned this . . All to no avail. I was told that it was probably bad fuel and/or water in the fuel).<br /><br />I pulled some fuel from the bottom of the tank (I have a bottom drain for such a purpose) and noted no water. Also put dry gas in tank.<br /><br />Well, the 90 hp finally died as describe above. We replaced it with a 150 hp 1984 Evinrude. A very clean engine, Carbs rebuilt, good compression, etc. Well, the engine was installed, tested statically without the houseboat moving. Took the houseboat out for the first time last evening and lo and behold . . .same problem!!! At first the engine was perfect. THen, within about 10 minutes, rpms began to fall and it would sometimes leap to full for a few seconds then drop back. If engine was stopped and restarted, it would go to full throttle, but then fall back and surge.<br /><br />1. What could be the cause?<br /><br />2. If it is bad fuel, could running the engine with bad fuel cause scoring of the cylinders/the demise of the prior engine!!!<br /><br />(The fuel in the tank was fresh and did have Stabil in it)
clanton
Re: 84 Evinrude - Balky High Speed Operation
I would remove the pickup tube, all fuel lines, and anti-sipheon valve for an inspection. The 150 should have 3/8 hose and fittings. All fittings should have inside diameter of 9/32. The little glass filter may have 1/4 nipple, too small for this engine and the 90 hp. How many rpms at full throttle?
scarchest
Is your control box hot horn functioning, sounds to me like your motor may be overheating
ddonald
Can't really give rpms since tachometer is inoperable (new on order). All fittings are 3/8" and glass filter is a large bowl type with 3/8 fittings. One final point of interest is, when the 90 hp was on the boat and this would happen, with the engine running and squeezing the bulb, the bulb would stay compressed (not "inflate"). Hopefully this is another clue. Bad primer bulb?<br /><br />Overheat horn working properly. No overheating.<br /><br />Thanks
Backlash
Hey Dale, Is the fuel tank vented? Check to be sure the vent line isn't blocked or kinked.<br />Backlash
rogerwa
Gotta be between the bottom of tank and the bulb. Clogged vent, pickup, bulb or antisiphon.. Cheap stuff just to replace in any case..
