Tachometer for 1978 Mercury 500 Thunderbolt
lgaytan
Hi,
what kind of tachometer I need for my outboard? 1978 Mercury 500 Thunderbolt 50HP S/N
4967035, after some tweaks I think it is running good but even being a small engine it is a thirsty one, it consumes too much gas to what I believe should be doing, we usually go WOT I want to change that and find the cruise speed, having a tachometer I believe will help.
Last trip I estimate we traveled 33 miles total and consumed almost 10 gallons of gas. We were 3 adults, a full 40 qt cooler, a 20 pound anchor and some fishing equipment, I don't think we were specially heavy. Anyways, what tachometer do you suggest?
Regards
What size boat ?-----How long did trip take ?----Check fuel pump diaphragm ??
You should be burning about 25 # of fuel per hour with a 50hp 2-stroke
You will burn more getting up on plane
lgaytan
The boat is 15' long, I'm unsure of the lenght of the trip but we were running average 25-26 mph, that means that over all it was 1.3 hours more or less. According to what I have read the rle of thumb is that my 50 hp will burn 5 gph. It should had been 6.5 but we burned 10. There are things to fix still, I noticed that the hull has a crack and water is comming in there's more weight there.
Have you tried the tiny tachs? are those reliable?
Tiny tachs are ok. However any outboard 2 stroke tach will work
What speed does your boat plane at? If you hover around that speed, you will burn more fuel than you would at WOT
lgaytan
not sure what is the plane speed, how can I check this?
