what does acc switch do?
creative76251
hello i have a Invader Boat MWK40980M83G on the dash board fisrt switch on the far right what dose it do it says Acc but when i turn it on nothing happens. I also Need a boat manual for this boat so if u could please give me a link to it that would be good.<br />thanks
mkuehnl
Re: what does acc switch do?
Acc Is "accessories", which you may not have any. That may be the reason nothing happens. Usually it would be used for elec. things that you might add at a later date..<br /><br />Just my $.02
Creative, The acc switch is used for accessories such radios, cigar lighters, depth finder, GPS etc. I recommend that you wire it so that when you turn it off, everything shuts off. That way when you leave the boat you only have one switch to turn off, and your battery will not run down.
