DevinM
Thread starter- Joined
- Jun 16, 2020
- 28
F9.9SJ
669 S 001497
Picked this up yesterday. Dude was sure to mention I need to drop lower unit.
When I removed the lower unit the shift shaft that goes into the foot popped out.
My main two questions about my situation is when putting it back in, do I have to pass the ‘forward’ position to get the foot in neutral and the shaft seated? Trying it a bit last night is seemed like it would not go past the first spot where I found a gear.
Next is about the little plastic piece (682-44176-00-00 )that was found just sitting on top of the shift rod boot. It looks like some sort of retainer that would keep the seal air tight. Has a slot and screw that it must slide into something. Only place it fits is resting on top(picture of where it fits attached). I wish I could be more clear.
When this is assembled, I should be able to pull the shift shaft up for forward and all the way down for reverse right? This is my first Yamaha after a good few 2 stroke Johnson’s.
669 S 001497
