The Force power
- Feb 3, 2019
- 2,267
Hi Nordin,The Force power does it fire twice when hooking up a second battery to the charging system and is it charging lower amps or does it affect the spark at all cylinders?
If I do not remember wrong the stator has two or three windings. Two (or one) for charging the capacitors in the CDI boxes and one for charging the battery.
Can you explain more and how you notice possible double firing.
Thanks for tuning in.
I bought
CDI Electronics 176-3095 Chrysler/Force/Sears/Gamefinder Stator - 2/3/4/5 Cyl (1984-1992)
I have not tried to hook a second battery to the charging part, forgive my ignorance but firing (and/or twice) would this not be a trigger issue?
I pulled all the plugs & ground them crank-over the motor (with the timing-tower/trigger in the idle position)
All cylinders fire "around" their respective TDC
I think I saw it fire with the lead on #1 cable/coil fire twice?
when I increase the RPM (while running) the bucking/hick-up becomes more violent
With the #1 & #2 plugs out & grounded the engine runs somewhat smooth / no bucking / sudden stall
