The Force power
Thread starter- Joined
- Feb 3, 2019
- 2,359
THANK YOU!!Called an equalizer tube.
It equalizes the pressure/air flow between the carbs.
Really doesn't do all that much but it makes it run different when not installed.
Dug some deeper & found in motor / vintage cars forums that it helps with the adjusting the Carbs ( some have and some don't depending on the manifold )Called an equalizer tube.
