Fuel tank dual line for 1957 Evinrude fastwin 18 hp model 15020
Afterwalleye
Fuel tank dual line for 1957 Evinrude fastwin 18 hp model 15020.
For the above fuel tank, which line is fuel and which is dedicated for air? Looking at the connection on the motor, is the fuel line on the left or right?
Crosbyman
side connector inside hose to the side nipple behind the carb is AIR the other is fuel to the carb bowl
just follow the hoses
the side connector is not the problem... do not reverse the dual hose on the tank.
Crosbyman
on the tank side if you pump the push button you will see which is which fast :)
