60 efi Bigfoot won’t idle.
av8erdunn
I have a 2007 Mercury Bigfoot 60 EfI that has developed a problem. It will start and idle for about 5 seconds and then it shuts down. I was able to play with the choke and throttle and it would run at 4,000rpm on the water hose but would want to die off at anything below that. I am guessing I need to check fuel pressure at the VST tank to see what it is but other than that, do y’all have any recommendations? Thanks in advance
Go thru the fuel system and clean it. My guess the injectors are plugged
QBhoy
If you mean pushing the key in to choke…it’s likely you might not be doing anything there…if she’s an efi. Anyway…
Things I’d check, if she was my own…
I’d quickly check the voltage measured at the battery, just before and up to she starts to run poorly or not at all, when lower in the rpms. Rule out any insufficient charging reasons out of play. At the same time…rule out a compromised stator, regulator and battery too (a small engine like this is easily turned over by even a poor battery, but only a decent battery will be man enough to run ignition, fuel and sensory items sustainably..especially at lower rpm)
Then, armed with a fuel pressure gauge (of your choice…obtainable for not far off $10-20 online), check the fuel pressure in and up to the aforementioned state of running.
I’d then check the voltage and position set up of the tps (if she is efi). Check the throttle body operating too.
Measure the continuity of the coil packs and leads.
Check (probably should have came further up the list in order) if you have a fuel rail filter screen. Good chance you might. Certainly from around then onwards, they usually do.
Good to determine (if we are thinking it’s a fuel issue) and prove the presence of fuel delivery at given locations along the delivery route. So assuming the fuel tank primer bulb is in good shape and fitted in the correct direction of flow, the tank and engine fittings are in shape (not drawing air, especially if it’s the newer plastic quick connect type)..then the presence of adequate fuel pressure at the test point on the rail…and the rail fuel screen is clear…all that’s left is an injector issue. This is usually quickly indicated, by the sensory told presence of fuel in the oil. Smell and sight. Often even indicated by a higher than normal oil level on the dipstick.
Finally…failing all that…back to electrical and sensory items. In brief..if you are getting a decent voltage indication and sustaining…it’s odds on to be a fuel related thing. Start simple, at the tank and delivery then work up towards vst and the usual seal perish issues within.
Voltage, electrical integrity (including terminals and earthing) and fuel.
av8erdunn
Wow!! Thanks for the write up. Just getting back to this. I pulled the VST apart and found that the filter at the regulator was plugged and the filter at the bottom of the electric fuel pump was de screened as someone had removed the screen. I went ahead and bought 2 new filteres and pulled the injectors and sent them off for cleaning. Installed everything and it was doing the same thing. Bought a fuel pressure gauge and I turn the key on and I get 13.6 psi. Now the question is, is it the regulator or the pump? Tempted to just buy a whole new VST and be done with it but I’d rather not waste money if not needed.
av8erdunn
Faztbullet
I use WSM aftermarket pumps with no problems. If you try this one the first thing I would do is remove the decal on it. WSM pumps are laser engraved.
