Volvo Penta Tool Kits for Drives
Phil*
Does anyone know specifically which tools are included in the "level 1" service kit PN# 3855955 for the DP-S drive? VP says it has everything needed to disassemble and reassemble the lower unit and reseal. There is another level 2 kit for shimming gears. I'm wondering if the level 1 kit includes any of the drivers and pullers used on bearing races and want to know what I'm getting for $1k. The cost of specialty tools for working on these things just about has me ready to jump ship to a different boat, haha.
Fun Times
The following appears to be an visual itemized list for 3855955. Not seeing anything for 3856041-3
Lower Gearcase — "DP" Dual Prop
Service tools (figures 1 thru 13) are available as Service Tool Kit,
Part No. 3855955
[1] 3855876 Propeller Remover/Installer
[2] 3855877 Spanner
[3] 3855919 Propeller Shaft Adapter
[4] 3855920 Nut
[5] 3855921 Pusher Tip
[6] 3855922 Tube
[7] 3855923 Driveshaft Puller
[8] 3855924 Seal & Bearing Remover
[9] 3855925 Seal & Bearing Installer
[10] 3855926 Support
[11] 3555928 Seal & Bearing Installer
[12] 3855930 Pinion Nut Holder
[13] 3855932 Fill Adapter
Click Here to search for 3855955 on eBay
and the $1k worth of specialty tools doesnt include dial indicators, bearing nut spanners, mics, torque wrenches or hand tools
Phil*
Very true, but fortuneately I've got a good selection of the "general" tools like that on hand. As a DIY'er the number and cost of specialty VP tools required is getting me to reconsider this brand. Live and learn I guess.
alldodge
Merc has a lot of costly special tools also. I bought several just to rebuild the lower
agreed, the VP tools are not any more expensive than the Mercruiser tools
Phil*
Good to know, Makes me feel a little better. I'm not familiar enough with Merc special tools... Just noticed a lot more aftermarket Merc tools so assumed they were a lot cheaper.
alldodge
Biggest issue with VP parts is the cost of them, Merc is high but VP is higher
