Lou C
- Nov 10, 2002
- 13,878
When I had my issue with leaky head gaskets & salt water in the oil I spoke to a few mechanics & both said the same thing water in the oil or even antifreeze will deteriorate bearings & you might not know that there bad till you put a load in it. In my case the water wasn’t in the oil long enough to damage them, even though it’s the original short block the oil pressure is normal. Cold idle oil pressure on that engine should be about 40-50 psi depending on what viscosity oil you use and the air temp.
I agree with the likelihood that there are cracked engine components if a core plug was pushed out.
