Scott06
- Apr 20, 2014
- 7,338
that is not how a power valve on a rochester 2 jet or Mercarb works.I hooked a vacuum pump up to my power valve to check for leaking and it seems to hold about 20 max and then quickly starts leaking. At 7” Hg it leaks very slowly and stops leaking at 3.6” Hg. If anyone knows if this is normal it would be much appreciated thank you.
I also noticed that the Venturi holes on the new carb are slightly larger than the ones on my old carb.
There is an piston/actuator that comes down from the airhorn and pushes the power valve open. At high vacuum/low throttle opening the piston gets pulled up into the airhorn and doesnt push the plunger on power valve open, when vacuum drops the piston comes down and open the valve to richen fuel mixture.
you are just pulling the power valve open with the vacuum. here is a vid on how it works
