New to us Boat!
TheMrBeaumont
We just bought this 1985 bomber boat, but we don’t have any idea what model it is and it has a Johnson motor 60 hp. Model #J6TLCO… I’m guessing the last letter is “D”. How can I find out how many strokes it is? We plan on repainting it and putting foam flooring on this winter. IMG_2131.jpeg
Crosbyman
carbed 2 stroke vro oiling 2 cyl. according to the parts place....
time to get yourself a manual :)
drain the GC and refill check for water when you open the bottom screw
if water drips out first or oil is milky chocolate a gc reseal is likely needed ... pressure test the GC
pull the prop check for layers of mono line chewing the prop shaft seal
TheMrBeaumont
if water drips out first or oil is milky chocolate a gc reseal in needed ... pull the prop check for layers of mono line chewing the prop shaft seal
Thank You
Check the integrity of transom and stringers.---No point putting a new floor over rotten stringers.-----Find a owners manual for this motor.----Read it 2 times before your first launch of the boat.
