- Jul 23, 2011
- 51,870
something wrong if you only get 244 hp out of a 383Attached the Dyno graph here…
Yes plenty of rot. The transom and engine stringers were removed and replaced. Transom built to merc spec.What condition was the transom in when you rebuilt it? Was there rot?
SISTER the 1980's buy it 1979 then 1988 sold it .... SEA RAY 1970 24FEET .....Roy - I’m sorry your sister was a 24’ Sea Ray ! I’m not too sure what you’re asking though,
yes that resin polyester wooden then the fiber glass ....I did not paint any wooden surface. It’s all fiber glass over.
On the bottom right of the graph it reports max hp as 244 which matches the graph. You have to download and blow up the pic to seeit. If you pd for 360 tell them to show u where on the dyno graph it is. The power falls way off at higher rpm likely due to the carb used it ran out of air. It said AFr ratio was calculated, which is bs cause an afr meter costs like $400 all in .I don’t have it in the report but I was told it made 360hp (advertised as such too) maybe the dyno company can give me a better report.
Thank on the compliment, we really enjoy the boat and the new reliability aspect. Just working out the things like this. Believe it or not the injectors are the same part number for both engines…
Right on. They’re good ole boats!SISTER the 1980's buy it 1979 then 1988 sold it .... SEA RAY 1970 24FEET .....
Did the very good boat ....I was buy it in Florida 1979 ... MY sister is MASSACHUSETTS ...
I will call the dyno sometime and see what they say. When I ordered it I thought it was to test its capabilities but when picked up it was presented as a break-in dyno.On the bottom right of the graph it reports max hp as 244 which matches the graph. You have to download and blow up the pic to seeit. If you pd for 360 tell them to show u where on the dyno graph it is. The power falls way off at higher rpm likely due to the carb used it ran out of air. It said AFr ratio was calculated, which is bs cause an afr meter costs like $400 all in .
If you paid extra for dyno time id be pissed, if it was only to break in-then that is different. With a bigger cam yeah 360 makes sense as a little bump from stock 340 hp, but you need the fuel to do that.
When reading plugs they show what you last ran which was likely idle to read them you need to run at what ever rpm you want to look at afr then cut it off immediately and pull a plugHere’s two plugs from each side. A little reddish. According to the charts I’m on the lean side but not dangerous. Does anyone think differently? Thanks!
The 555 doesn't know the AFR, it just has fuel tablesGot it. Yes idled for maybe 3-4minutes after full throttle. How does the 555 know the AFR?
350 | |||
| bore | stroke | ||
4.001 | 3.48 | 12.573 | 350.024 |
4.03 | 3.48 | 12.756 | 355.116 |
4.04 | 3.48 | 12.819 | 356.881 |
4.06 | 3.48 | 12.946 | 360.423 |
