Guard rail gone slack, sailing cruiser.
janul15
Hi, on my 30' sailing boat, all the wire guard rails have become slack. The barrel adjusters are at their limit. How can I remedy this?
alldodge
Have not messed with them but I would first look at what is causing them to go slack. Did the rails bend or is the deck holding the rails getting soft
@tpenfield may have some ideas
Grub54891
If the stanchions are loose where they attach to the deck, there is the issue. If every is solid down there the rails have stretched over time and they will have to be re-swaged or replaced.
pictures would help.
Life lines could have stretched
Some stanchions could be bent or loose
Top rail could be bent
Make sure the top rail and all stanchions are 100% factory spec
Then loosen up the turnbuckles, and redo the anchor termination studs. Should be a nut and ferrule arrangement.
Could also be swagged
After that, tighten the turnbuckles
janul15
I should get you pictures in a couple of days. I didn't think the stanchions or metalwork is the problem, more likely the wire lines (lifelines) are stretched. What does swagging/reswagging mean
Look on sites like suncor stainless for lifelines and various methods of securing lifelines. And compare to what you have
flashback
swaging is the process by which the threaded stud is fastened to the end of the life line..
Here is the suncor link
You can see if it's swagged or the quick connect fittings
janul15
Here are 2 pictures, badly focused. I'll look through Suncor to see what matches. I think I'll need lengths of cable, the connectors, and some tools.
janul15
Forgot to attach.
looks like swagged ends. If all your stanchions are in order, I would just get a few quick-connect ends, cut off the swagged end, and redo the terminations
check your local rigging shop to see what they have on-hand.
