Most stable hull design for trolling in rough water
Hello everyone,
I was wondering if someone with a lot of experience could tell me what is the best hull design for stability in very rough water. I was out trolling the other day in my V hull Bayliner and was having a good day until a couple of wake boats came by, and threw real tall waves up against the side of my boat! I have a 20 foot Bayliner Capri and if it gets hit on the side of the boat while trolling with a big wake it rocks back-and-forth like a bobber! I was curious if a boat with a flat or near flat hull wood be more stable in the water than a V hull while trolling ? Any help would truly be appreciated!
Deep vee hulls with lots of deadrise angle
What is the deadrise on your hull?
Thanks for your reply. I’m not sure what the deadrise is my boat since it’s a 1992 and I bought it used about 5 years ago. I’m not sure how to find it without the owner’s manual. I noticed a Hewescraft not too far from mine and about the same size as mine that was trolling as well. Those boats have a fairly flat hull for running up rivers and I noticed that it wasn’t getting tossed around as badly as my boat with the wake hitting it on the side like mine. I’m not sure why?
tpenfield
There may not be any good solution to the issue you described. Would you really go out and buy a different boat just to resolve a tipping issue?
Decent sized wakes against the side of the boat is definitely going to be a rocky ride. Wider beam can help, but maybe not all that much.
The whole idea is to have a bigger boat, so you can return the 'favor' when the opportunity presents itself :LOL:
If you do get another boat at some point, look for more freeboard.
Very true! I once had a tall wake that hit the side of the boat where some water washed over the side and into my boat! I finally left that part of the lake and tried fishing in a different spot. Trouble is that the place I left was very good fishing!
dingbat
When trolling, the snap roll of a deep Vee will give you whiplash.
A heavy, mod-V or continuously variable vee hull design is your best choice for trolling
The sharp bow entry cuts the waves and a rather flat transom minimizes rocking on the troll.
Thanks for your response, I think that you’re right, and it makes sense that a flatter transom helps to control rocking back and forth when trolling. I really do like how the deep v cuts through the waves and chop. I do believe that the hull gets much flatter towards the stern, but the boat is fairly light for a 20ft boat. It only weighs about 1700lbs. The I/O version weighs about 3000lbs. I’m sure the weight has a major role to play in controlling rocking in the water, along with the beam of the boat.
dingbat
While weight, in the right places, plays a big role, hull design plays a huge role in how the boats reacts on the troll and in the rough.
Yes sir, I think I’ll have to look into that! Give them some of their own medicine 😉
