kirk elliott
Thread starter- Joined
- Sep 2, 2023
- 9
anyone know why I've no tell tail sign of water while flushing my kicker ?
It’s a new motor 25 HP tried muffs then tried a big tub inlet well under water still no tell tail, I’m thinking might have to buy a owners manual to know more about the flushing port ( new modern gear kinda worried might flood the cylinders )How are you flushing it ? With the muffs or is she of an era to feature a flushing port not requiring the engine to be ran. Depending on the size of the engine, most flushing muffs on small engines really struggle to form a good seal, should it be the former of the two above. Has flushing been successful and water from tell tale previously ?
The newer type mercs with flushing hose attachment type port, won’t flood the cylinders. If that helps you any.It’s a new motor 25 HP tried muffs then tried a big tub inlet well under water still no tell tail, I’m thinking might have to buy a owners manual to know more about the flushing port ( new modern gear kinda worried might flood the cylinders )
On the ocean it has tell tail indication
I’m guessing this is the port ?The newer type mercs with flushing hose attachment type port, won’t flood the cylinders. If that helps you any.
Not sure where to get a fitting to attach to this . The standard garden hose leaks like it’s plugged no sign of letting any water throughI’m guessing this is the port ?
Assume so, but not certain to be honest. Mine has a pull out cover on it and slightly different I’d say. 2016 mercury 115. Have a look in the manual. Should be the usual garden hose fittingI’m guessing this is the port ?
That actually is the same as mine. It’s the standard garden hose female fitting that goes on there. Quick connect thing. Or it is where I am anyway. See picture below that goes onto the hose and the quick connect snaps onto that fitting on the engine.I’m guessing this is the port ?
See that fitting there you have. The male hose quick connect. For certain, you will get a female connector on there…but I have a feeling that that fitting you have there, may have been fitted additionally by someone previously perhaps. It may well unscrew from a thread there. Leaving you with the hose fitting thread that you may be more familiar with, in your area perhaps. Lots of info on it online or YouTube. Not something I’d usually steer anyone towards..but mercury themselves have a few videos on this very subject. You need to make sure the engine is tilted down and the engine should not be started when using this method. It’s designed specifically for flushing without running the engine.I’m guessing this is the port ?
