Unidentified wire
alldodge
No issue with oil pressure. Oil gets hot and pressure drops, is no issue over cold motor. Your well above any issues where hot oil would be a problem
Scott06
Yeah i knew that a 21p 4 blade was equivalent to a 3 blade 23 and idk how the 4 blade did on the original boat it was on with this same engine i never really went full throttle because i was watching my rpm and i didn't over rev because I made sure to keep my eyes on the shop tach because testing was the main reason I was out there. I was just throwed back because for that prop to be the same as a 23p it shocked me at the speed lose between the 2. I'm just not sure weather to try a 21 or a 23 3 blade next ..
Also what did you think of the oil pressures ?
Your oil pressure is fine as a rule of thumb 10 psi per 1000 rpm is perfect so at idle 25 is great
You didn’t mention what is wot rpm for both props . You said at 3/4” throttle
What are both props running at wot
EBRAMS
Just wanted to make sure
The 21p 4 blade I was running 4600 rpm at 3/4 throttle so I didn't go wide open and the 19 pitch 3 blade I was running 4400 @ half throttle so again I didn't really test at full throttle.. it's my understanding that max rpm is 4400-4800 is that correct?
The 21p 4 blade jumped up nice but it just wasn't hitting on much in the way of speeds so I jerked it off and put the 19p 3 blade on and got better speeds I think
alldodge
Your WOT should be real close if not on 4800 rpm
4400-4800 is good and closer to 48 is better
Scott06
If you havent hit wot with either you dont know what they are capable of .
This is the classic tradeoff on how you want to use your boat. If top speed is more important to you use the 3 blade. If you want better holeshot especiallyif loaded with people 4 blade is probably better
as mentioned U want to hit 4800 or so at wot this will prop the boat to be throttle responsive in all rpm ranges …there is a rev limiter so you wont over do it
EBRAMS
Yeah I realized on my last run that my in dash tach was off by 400 rpm at 4800 rpm so when the dash says 4800 the shop tach reads 4400
